Results 1 to 10 of 89
Thread: Iron in water source
    BigDave's Avatar
    Default Re: Iron in water source
    I'd let the filter go without backwash until the pressure is about 8lbs over clean. The dirtier the filter, the finer debris it will remove. Try to vacuum to the filter and see if the orange stays in. We already know it catches the calcium precipitate. I also think you can let the pH continue to float up to 8. PoolDoc may correct me when he returns but I'm pretty sure that's the plan.
    Jul 2013
    Northern Illinois
    BigDave is right! Make that filter work. Also, you may consider adding DE to your filter via skimmer. (See sticky). We will all be joyous when PoolDoc returns in full! Also still wondering about cal-hypo dosage.
    Aug 2014
    Virginia
    Default
    AM:
    Have backed off to 1 tab per skimmer per day. Will vacuum to filter this morning and see if it will catch and hold the sediment. I really do appreciate your help
    PM:
    pH 8.0, Vacuumed to filter. Basically captured nothing, returns basically putting what I vacuumed back into pool. No change in pressure and returns remain strong. Getting pretty frustrated.
    22,000 gal. 30' round IG, vinyl liner, sand filter, 1 HP pump, BBB method
    Taylor K2006c & K1000
    Jul 2013
    Northern Illinois
    BigDave: I am thinking that there was not enough calcium on the filter media to catch the sediment. He is only using 1 tab cal-hypo and has been doing a lot of back-washing. What do you think?
    BTW, here is a link to adding DE: http://www.poolforum.com/pf2/showthr...to-sand-filter
    BigDave's Avatar
    I'm concerned that the filter is not working properly. As FormerBromineUser suggests, you can add DE to a sand filter to get it to catch smaller particles. You can test the filter with some DE as described in this link: http://pool9.net/de-test/. please do as it sounds like your filter is not working correctly.
    Aug 2014
    Virginia
    I will get the DE and try it. I've been concerned that the filter is not working correctly also. As I mentioned I had the sand replaced when I had to replace the liner. Was something done wrong or any idea what it could be? Right now have towels is both baskets. Catching lots of mineral. Rinsing and repeating. Probably just entertaining myself as it would probably take a month of Sundays. Was hoping the reduced flow would allow sand to begin to catch something. Flow still strong however. Please understand my frustration is with my pool, I appreciate all the time you, FormerBromideUser and PoolDoc have given this. I've had a pool 15+ years and never had to deal with a metal problem before. Wow!!!
    Aug 2014
    Virginia
    2/3 cup DE increased pressure 1 - 2 psi
    pH 7.2, FC 5
    Metal in solution, water opaque green.
    Still doing 1 cup polyquat every other day.
    Guess it's time to begin the cal-hypo again?
  1. Iron In My Water
    By Phenom300 in forum -- Subscriber Posts --
    Last Post: 08-16-2014, 08:18 PM
  2. Iron out to treat iron and tea colored water
    By Fornetti in forum --cleanup--
    Last Post: 07-02-2013, 02:56 AM
  3. Well Water very High Iron
    By meadsrm in forum Pool Chemistry for Intex-type Pools
    Last Post: 06-05-2012, 02:58 PM
  4. New Pool Owner With High Iron Manually Removing Iron
    By labdi01 in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 06-18-2010, 02:56 PM
  5. Aerating Water to Get Rid of Iron
    By smallpooldad in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 09-27-2006, 09:59 AM
