Results 1 to 10 of 89
Thread: Iron in water source
    Aug 2014
    Virginia
    Default Re: Iron in water source
    Yes
    22,000 gal. 30' round IG, vinyl liner, sand filter, 1 HP pump, BBB method
    Taylor K2006c & K1000
    BigDave's Avatar
    Is the filter pressure rising? Are the returns getting weak or is there poor skimmer action? Do you have a 2 speed pump?
    It seems clear that the chlorine / raising pH is making the iron come out but it's not settling on the filter as we'd hoped.
    Aug 2014
    Virginia
    Pressure not really increasing. Returns are strong,1 speed pump (1HP). Had sand in filter changed (200 lb., I think) when I had liner placed
    Agree with your assessment, filter does not seem to be capturing much iron.
    Jul 2013
    Northern Illinois
    Are you only adding 1 cal-hypo tab per skimmer per day or the half pound max recommended by PoolDoc?
    BigDave's Avatar
    I'd let the filter go without backwash until the pressure is about 8lbs over clean. The dirtier the filter, the finer debris it will remove. Try to vacuum to the filter and see if the orange stays in. We already know it catches the calcium precipitate. I also think you can let the pH continue to float up to 8. PoolDoc may correct me when he returns but I'm pretty sure that's the plan.
    Jul 2013
    Northern Illinois
    BigDave is right! Make that filter work. Also, you may consider adding DE to your filter via skimmer. (See sticky). We will all be joyous when PoolDoc returns in full! Also still wondering about cal-hypo dosage.
    Aug 2014
    Virginia
    Default
    AM:
    Have backed off to 1 tab per skimmer per day. Will vacuum to filter this morning and see if it will catch and hold the sediment. I really do appreciate your help
    PM:
    pH 8.0, Vacuumed to filter. Basically captured nothing, returns basically putting what I vacuumed back into pool. No change in pressure and returns remain strong. Getting pretty frustrated.
  1. Iron In My Water
    By Phenom300 in forum -- Subscriber Posts --
    Last Post: 08-16-2014, 08:18 PM
  2. Iron out to treat iron and tea colored water
    By Fornetti in forum --cleanup--
    Last Post: 07-02-2013, 02:56 AM
  3. Well Water very High Iron
    By meadsrm in forum Pool Chemistry for Intex-type Pools
    Last Post: 06-05-2012, 02:58 PM
  4. New Pool Owner With High Iron Manually Removing Iron
    By labdi01 in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 06-18-2010, 02:56 PM
  5. Aerating Water to Get Rid of Iron
    By smallpooldad in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 09-27-2006, 09:59 AM
