Results 1 to 5 of 5
Thread: Clorox
    Default Clorox
    Is anyone using clorox bleach to clean their pool? Any help would be appreciated
    mbar's Avatar
    mbar is offline Lifetime Member Whizbang Spinner mbar 3 stars mbar 3 stars mbar 3 stars mbar 3 stars
    Ashland, PA
    Default Re: Clorox
    I use chlorox, and any brand that is on sale - plain bleach, no additives. I try to get the ultra which is 6%
    Northeast PA
    16'x32' kidney 16K gal IG fiberglass pool; Bleach; Hayward 200lb sand filter; Hayward pump; 24hrs; Pf200; well; summer: none; winter: mesh; ; PF:7.5
    tundraSQ is offline Registered+ Thread Analyst tundraSQ 0
    Default Re: Clorox
    Quote Originally Posted by Karo123
    I think we all are using it to sanitize our water...what do you mean by "clean your pool"? Are you talking water or pool?
    bcb1 is offline ** No working email address ** bcb1 0
    Default Re: Clorox
    Yes. Bleach (Clorox or any brand) is just plain chlorine. It generally comes in 5% concentration for regular bleach, and 6% concentration for "ultra" bleach. That means 6% chlorine (sodium hypochlorite) and 94% water.
    You can go to the pool store and buy "liquid pool chlorine" - it's just bleach, but it's a higher concentration, usually 10% or 12%. But it's often much more expensive than plain old store brand bleach, and if it's been sitting on the shelf for a good while, it's probably decreased in strength.
    So the answer is: feel free to use plain old bleach as a pool sanitizer. It's cheap, and it doesn't have any of the "gotchas" that using tri-chlor chlorine pucks have.
    Default Re: Clorox
    I moved this to the Chlorine forum, from the automatic cleaner forum.
  1. Greetings. Thanks. Clorox?
    By cayenne in forum Pool Chemicals & Pool Water Problems
    Last Post: 08-05-2012, 05:02 PM
  2. Clorox and Freezing
    By CyberGypsE in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 11-05-2007, 06:23 PM
  3. Help! Help! New Improved Clorox
    By poolmimi in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 04-06-2007, 01:16 PM
  4. Clorox
    By Karo123 in forum Pool Cleaning: Manual or Automatic
    Last Post: 06-23-2006, 07:21 PM
  5. clorox
    By rainhill in forum Pool Chemicals & Pool Water Problems
    Last Post: 04-26-2006, 01:48 PM
