Hi,
I have the Goldline Aqualogic Salt system. My controller is model AQL PS 8 and have had since 2006. When switching between Pool and Spa, the return actuator does not turn. I have narrowed it down to the return port on the board as I can switch the connections for the actuators and both work when plugged into the intake port.
Since I have narrowed it down to the port on the circuit board, is there a way to program the spa/pool setting to use one of the available valve ports in place of the return port?
Thank you
