Thread: Vacation & Chlorine Levels
    Mar 2012
    Tennessee
    Default Vacation & Chlorine Levels
    We will be going on vacation for about 9 days. The question: Should we put a couple gallons extra of bleach in before leaving and some chlorines tabs in a floater ? Going to turn the pump off. Afraid the sun will evaporate the water level to below the skimmer and burn the pump up. The pool is in direct sun light all day long. Really don't want to come back to a green pool. Any suggestions?
    1 1/2hp Emerson 2speed pump, BBB
    27' round 19.3K gal AG Vinyl Liner pool; sand filter; pump: 24 hrs on low; Taylor K-2006 FAS-DPD Chlorine; utility water ; PF:6.9
    Mar 2012
    Tennessee
    Default Re: Vacation & Chlorine Levels
    Thanks.
    You're welcome!
  1. Pool Survived Vacation! ?? Chlorine levels
    By mroll in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 08-11-2012, 12:39 PM
  2. Going on vacation, what chlorine level to leave pool at?
    By sunlove in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-12-2012, 01:33 AM
  3. chlorine levels
    By fhorta in forum Dealing with Algae & Slime
    Last Post: 05-26-2011, 05:26 PM
  4. How often to test & how much chlorine to add daily? Also, vacation upcoming...
    By blessedbeingmom in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 07-16-2010, 09:36 AM
  5. Low Chlorine Levels
    By BigButz in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 06-16-2007, 07:42 AM
