Results 1 to 10 of 20
Thread: Question in regards to pool plumbing
    Default Re: Question in regards to pool plumbing
    I'm not sure about the 1.5 to 2" connections, but I do wonder why you don't go 1.5" all the way.
    There are special glues formulated to handle CPVC heat, and I believe they can be used for PVC as well. But I'd be leery of using PVC on CPVC where there's heat.
    DennisP is offline Registered+ Thread Analyst DennisP 0
    Jul 2014
    New Berlin, WI
    Well, considering the pool is 70 feet away from the equipment pad I am trying to limit head loss. Since I am doing the installation, I figure 2" is the way to go, since the price is negligible compared to 1.5".
    Also, since the filter is 2" connections, the heater is 2" connections, it just kinda makes sense to keep things 2" all around as much as possible.
    I have hard that a single 1.5" fitting isn't as big of a deal as all 1.5" pipe, thus my query. I figure if folks have been doing this a while, someone would probably know if there are any issues one way or another.
    In regards to the CPVC to PVC connection, I will probably just use the CPVC cement to connect the nipples to the elbow and use a threaded connection to connect the opposite side of the elbow to the regular PVC piping then. I know the instructions for the heater state to use the CPVC nipples to connect to regular PVC piping, in which case they expect a glued connection. No big deal and I would rather be safe about it and I know the "preferred" method of CPVC to PVC transition is via male/female connections, so I will just go that route.
    Jun 2013
    Central Florida
    My pool had three 1-1/2 inch lines on the suction side of the pump all teed together to the 1-1/2 inch pump fitting. Then 1-1/2 to the filter and back to the pool. At the pool there's an in-floor cleaner valve to four circuits. I had the opportunity to change to 2 inch from the pump discharge to the in-floor valve - about 60 feet total. My discharge pressure dropped by about 1/3. Your fittings will cause some loss, but the 2 inch pipe is really gonna be the biggest factor. You can use two 45 degree fittings instead of 90's and save a bit more.
    Not sure about your combo valves or adhesive. There should be a way to adapt PVC to CPVC, but its not in my bag of tricks to know how. If your heater wants a 6 inch nipple, its probably for "straightening out" the water stream before it gets inside. Not sure how much you want to compromise that, but again, its not really in my bag of tricks. Sorry.
    Jul 2014
    New Berlin, WI
    Quote Originally Posted by nefretrameses View Post
    Yeah, I am more worried about the 1.5"/2" combo fittings/valves being a restriction point more than anything else...
    In regards to the 6 inch nipple, the only reason they have that is so that if there is a thermal control problem with the heater you don't melt connected PVC pipe (since CPVC has a much higher rated temperature). The issue has more to do with the potential heat of the manifold compared to the water, ie, if there is a thermal problem the water can be cooler but the manifold can get much hotter. By the time the thermal overload switches disable the heater the manifold can be much to hot for PVC to handle, so with CPVC and a length of 6" they are just anticipating that it would hopefully save the PVC up/downstream from the heater. The big concern outside of a thermal issue is if you don't put a firemans switch in and just shut down the pump/heater and water boils inside the heater. A much more common occurrence and 6" of CPVC is hopefully enough to protect any PVC downstream/upstream from the heater.
    I figure a short nipple with an immediate 90 and another nipple being threaded into a PVC female should afford for at least 6-8" of total CPVC distance. That coupled with my installing a firemans switch will make sure I don't run into that situation. The only time it *might* happen is if we lose power while the heater is running. At that point there isn't much I can do, so the CPVC should hopefully do it's job.
    Jun 2013
    Central Florida
    Makes sense. Didn't think about heat.
    Jul 2014
    New Berlin, WI
    Well, just figured out the rest of the plumbing on the pad and picked up the majority of what I need... Doing PVC hardline isn't cheap when you are talking about dozens of elbows, lots of couplers, etc, etc... Luckily I only have a single Jandy 3-way valve (I am still amazed at the almost identical flow rates for the 1.5-2" valve vs the 2-2.5" valve at <70GPM). I just have to decide on the check valves (Jandys are nice and sexy, the problem is that there are complaints of the actual Jandy valve on Amazon having the spring and pivot rust) and I am done...
    I am going to start plumbing things on the pad tomorrow... I only have 2 additional unions (one for suction line and one for return line where they come up after the shutoff valves), other than the half ones at the pump, the filter and the flanges at the heater. Other than that it will all be hardlined with no adjustability... I only have to order a couple of specialty fittings (like the 2" CPVC stuff) and then the only thing left is the plumbing out to the pool, which is all 10ft sections of PVC...
    Jul 2014
    New Berlin, WI
    Well, got everything built in the last three days, let it sit overnight and did a full system test using 1.5" flex hoses run to my 650gal hot tub as a water source... I ended up using all 2" fittings everywhere with the 1.5" connections at the pump... I also went with Jandy 3-way and check valves along with NDSPro ball valves/flap check valve for the heater backup protection...
    Everything tests out great!
    I noticed about 9.5psi of backpressure at the Sta-Rite System3 cartridge filter with the Dynamo 1.5hp pump on high... I also noticed that once I switched in the heater it basically added about 2psi of backpressure...
    With the Dynamo on low it showed about 2psi of backpressure...
    My Jandy Lite2 millivolt 250k btu heater worked great too... Started right up and heated the water great... I noticed that the 2psi of backpressure on low was enough to allow it to operate so I will have to check it once the entire system is plumbed in with 2" out to the pool and see if it still has the same pressures... I doubt it will... But in either case I will adjust the pressure switch to make sure it only comes on once the pump is on high... (I even considered a small 120v relay installed in the pump that would kickoff only when it was on high tied into the firemans switch loop as well, but we will see how it goes)
    My water feed with check and ball valve worked great as well...
    I let the entire system run on high dumping the first couple hundred gallons of water to flush out all the piping and the filter/heater/etc...
    In the end I am just happy I have no leaks anywhere and everything works as expected... Now to get the skid steer here and get the pool built!!!
  1. New Pump and Plumbing question
    By jefflj98735 in forum Pool Equipment & Operations
    Last Post: 03-26-2014, 07:01 PM
  2. Question about plumbing
    By phikappa in forum In-Ground Pool Construction and Repair
    Last Post: 06-07-2013, 10:59 AM
  3. Pool Main drain clog & plumbing question
    By Azsnook in forum In-Ground Pool Construction and Repair
    Last Post: 05-21-2012, 06:56 PM
  4. Plumbing checkvalve question
    By JohnInSoCal in forum Pool Equipment & Operations
    Last Post: 06-20-2006, 03:09 PM
  5. Quick connects plumbing question
    By jadedreams in forum Pool Equipment & Operations
    Last Post: 04-25-2006, 10:45 PM
