Quote Originally Posted by revhendrix
Hi - newbie here and help would be much appreciated. We just bought a house in the Winter with a 20,000gal IG pool (fiberglass/vinal liner) and a sand filter. We had it opened by a pool company on May 22. The pool has previously been treated with Baquacil and the pool company opened w/Baquacil prior to us having any knowledge about the stuff (never asked for our preference). After a few weeks of frustration and reading this forum, my husband and I have decided to make the switch to Chlorine!! We're in New England and the weather, being so bad of late, has helped with our decsion since we are a few weeks away from swimming with warmer water.
Background: after opening and shocking with Baquacil it was very cloudy, then the pool store had us add many chemicals to clear the water: sanitizer, clarifier, PH +, alum (to settle the dead algae), Baquacil ultra (don't know why we are very new at this). Meanwhile, we vaccumed the greenish, cloudy water and backwashed alot. We ran the filter 24/7, sometimes on skimmer, sometimes on drain. Now the water is clear and there is some areas of algae on liner and bottom that need to be vaccumed. It has always been difficult, if possible at all, to see the bottom in the deep end. Every time we vaccuum or brush this stuff it recirculates and clouds up the water and we start all over again............................
Now, water test at the pool store yesterday shows the following:
PH: 8
Baquacil level: 15
TA: 100
Ca: 200
After reading several of the conversion threads, I understand the process but have a few questions:
1. The pool store is trying to sell us a "super shock" instead of using bleach. Any good or are they just trying to sell me something I don't need?? At this point, I'm not too sure I trust these pool store companies........!!
2. When initially dumping the bleach (or super shock), do we run the filter as normal or do we run it on a different mode??
3. The sock: Is it best to use a sock on the skimmer basket when initially starting the process?? If yes, just so I understand this, do you put a nylon/panyhose around the whole basket and reinsert it?? Then rinse it off as nesessary?? How long unitl the sock is not needed??
4. Is changing the sand difficult?? Do we have to change it?? The pool company says they have a chemical to clean the sand so we do not have to change it?? Does this work?? (FYI-the sand was changed at the end of last season so I think it has very little Baquacil exposure).
5. I have a fear of fading the liner. I know I have to keep a level of 15ppm, but how far off are dangerous levels???
6. I'm headed to Leslie's to buy the FAS-DPD test kit. Is this sufficient?? No time to wait for Ben's kit.
Thanks for all of your help and suggestions in advance. I can see we'll be utilizing this website and forum the whole summer (i.e. which auto-cleaner to buy for a $700 budget? Aquabot or the Dolphin Diagnostic??)
Rev, welcome to the forum! You've chosen the right place to take control of your pool, as opposed to letting the pool dudes do it! A sand change is necessary, there is still 'baqua-crud' trapped in the sand. Baq and chlorine don't play well together, as you probably know.
As for the sock, use it until it comes out clean.
As for 'super shock' vs bleach: the difference is in the concentration. Use mwsmith2' calculator to determine how much you need.
Changing the sand is easy, I responded to a post this morning about it (you can search, or I'll spend a few hours trying to link it here)
Run the filteer as normal
Any more ?s, just ask we are happy to help you
