Thread: Coping / Deck expansion joint
    Apr 2014
    Texas
    Default Coping / Deck expansion joint
    I just had an in-ground pool put in about 2 months ago and the expansion joint between the coping and the deck has enlarged from about 3/8" to about 1". Is a 1" gap too large? I can't find any info on what the max size should be but most say it will run about 1/2". I just want to know if I need to be worried about it?
  1. installing new deck and coping
    By ArtCan in forum In-Ground Pool Construction and Repair
    Last Post: 04-17-2012, 11:49 PM
  2. Buying A House With A Concrete Pool, No Expansion Joints Around Coping - Need advice
    By grakk in forum In-Ground Pool Construction and Repair
    Last Post: 04-19-2011, 11:33 AM
  3. Type of caulk between coping and deck?
    By billhev in forum In-Ground Pool Construction and Repair
    Last Post: 05-26-2008, 10:16 AM
  4. Expansion Joint Necessary?
    By jkapit in forum In-Ground Pool Construction and Repair
    Last Post: 09-28-2006, 11:20 PM
  5. Caulk between deck and coping?
    By bhelme in forum In-Ground Pool Construction and Repair
    Last Post: 04-15-2006, 08:32 PM
