Thread: Calcium Buildup
    Jul 2014
    United States
    Default Calcium Buildup
    I'm sure this has been answered a billion times on this forum and I would just search for the answer but I don't have permission yet, so here goes.
    Is there a good way to remove significant (up to 1/4 thick inch deposits) calcium buildup on pool tile, or am I stuck with a pumice stone or bead blasting service?
    Thanks!
    Default Re: Calcium Buildup
    You can use this link to search the forum:> http://pool9.net/search/ It will search the entire forum and also our sister website www.poolsolutions.com
    But, until your registration is completed, you will need to be logged out to be able to see the rest of the forum. So, copy that link and paste it into a browser window after you first log out.
    Welcome to the Pool Forum!
  1. Fiberglass Pool Calcium Buildup or Fading Gel-coat?
    By rbabin in forum In-Ground Pool Construction and Repair
    Last Post: 05-09-2014, 10:02 AM
  2. Cause of calcium/scale buildup on perimeter tile.
    By poolaris in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 10-10-2013, 12:07 AM
  3. scale buildup help!!
    By marmstrong in forum Pool Chemicals & Pool Water Problems
    Last Post: 05-06-2010, 04:56 PM
  4. Spa Waterfall Calcium buildup
    By FlaPool in forum Pool Chemicals & Pool Water Problems
    Last Post: 07-01-2006, 09:03 PM
