Results 1 to 10 of 16
Thread: How long till chlorine level will drop
    Jun 2014
    Default Re: How long till chlorine level will drop
    A solar cover shouldn't make much difference.
    Check the Best Guess Chlorine Chart
    http://www.poolsolutions.com/gd/best...ine-chart.html
    19.5k gal, 16x32 vinyl liner, sand filter, 1hp single speed pump, K-2006 test kit. PF=6
    You can swim even at shock level with no problems. Just don't want to wear your best swimsuits that might fade.
    Jul 2013
    Northern Illinois
    How is your pool doing?
    rdefino is offline Registered+ Thread Analyst rdefino 0
    Jun 2013
    Haverhill, MA
    Doing good. Levels are fine, I shocked it and cleared it up about a month ago.
    Trying to get the most of it before the winter. We just started to get some more 80+ days so I'm trying to heat it up with the solar cover.
    Thanks for asking
    Oval 18x34 14400 Above Ground Dough Boy, DE Pentair
    Jul 2013
    Northern Illinois
    Great! Just curious... How are you testing your water?
    Jun 2013
    Haverhill, MA
    Using the Taylor K-2006.
    Jul 2013
    Northern Illinois
    Excellent! There's nothing better for giving you the confidence of being in charge of your pool. I am surprised that you are getting cold temperatures in Alabama. Here in IL, yes. But in the south??? Bummer. Enjoy!
  1. Chlorine drop ?
    By FNC1962 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-08-2012, 08:41 AM
  2. Chlorine level doesn't want to drop
    By bhc33 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-25-2011, 10:57 AM
  3. How much should chlorine level ppm drop?
    By smallpooldad in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 07-20-2008, 05:58 PM
  4. Chlorine level drop quickly
    By jdw-tx in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 05-27-2007, 08:00 AM
  5. Chlorine level drop
    By circlenranch in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 08-02-2006, 10:24 AM
