Sounds like your filter is damaged. However, even if the insides are damaged (the "laterals"), if the tank of the sand filter is fine, then you just need to replace the laterals, and, of course, the sand.
One of the few things I find generally reasonably priced at pool stores is filter sand. Using Home Depot's pool salt an SWCG is fine, but I would NOT use their sand.
