You need to get your water balanced before you start up the SWCG. Check your manual. SWCG units have specific requirements for how high the CYA level needs to be. You can either follow our Super Simple Start-up Recipe (it uses dichlor which adds chlorine and CYA at the same time) until your CYA level builds up to the needed level and then turn on the unit OR just add the needed amount of CYA separately and use bleach for a few days and then turn on your SWCG. Read about the recipe here:> http://pool9.net/ssr/
When you decide which route you want to go, let us know. If you decide NOT to use the recipe, we can talk you through the other way.
EDIT: Forgot to add this ---
(Until you registration is completed, you won't be able to see the rest of the forum while you are logged in. So, copy that link and then paste it into a browser window after you log out.)
