Sounds like it should work to me but it's really up to you.
The sand is contained in the frame. Is the frame strong enough to hold in the sand? Is it back-filled on the outside or supported in some other way?
Wood blocks under the legs should be OK at least for a while. Patio block would be better.
Where does the water go if the pool fails? will it destroy your neighbor's property or harmlessly flood the yard?
