Thread: Light Cord Rust Spot
    Jul 2014
    nevada
    Default Light Cord Rust Spot
    Hi my spa light kept tripping the gfi. I took it out and noticed a spot of rust on the cord/wire at the light housing. I let it dry and put a new bulb in. It stayed on but flickered. Do i need to replace the entire cord/fixture or could i possibly wire brush off the rust and goop some flexible epoxy/glue/cement around the rust spot? What type of epoxy should i use?
    Largo, Florida
    Default Re: Light Cord Rust Spot
    If there is any exposed wiring, you should replace the fixture (to which the cord is permanently attached). Having electrical wiring connected to a pool is a huge safety risk. Huge as in potentially deadly to you or your family or guests. I do mean to scare you here because of the risk that is involved.
    MAKE SURE you verify that your bonding and grounding are both spot on.
    If it is just discolored insulation and it reasonably seems like the discoloration is from some source other than the wiring its-self you still have the issue of why this light is flickering. Was the cord in contact with some metal (the niche)? It sounds like an incandescent bulb. If so, it could be defective. I've encountered incandescent bulbs that were defective from the get go. Bulbs can generally be had cheap from online sites like 1000bulbs.com.
    If you do decide to replace the light, do not pull the cord out of the niche yet. When you put a new light in, you can cut the old cord and use the old cord to pull the new light cord through the conduit easily.
  1. Growing black spot on bottom of gunite pool
    By love2float in forum In-Ground Pool Construction and Repair
    Last Post: 05-15-2011, 04:42 PM
  2. SC-60: How to pull the power cord
    By CAL7 in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 04-29-2011, 08:12 PM
  3. Do I have to level to the lowest spot within pool area?
    By robin640 in forum Above-Ground Pool Construction & Repair
    Last Post: 06-27-2006, 08:41 PM
  4. Changing Power Cord
    By Coolflee22 in forum Pool Equipment & Operations
    Last Post: 06-02-2006, 02:38 PM
  5. bad spot in shallow end
    By crosso in forum In-Ground Pool Construction and Repair
    Last Post: 05-25-2006, 02:29 PM
