Thread: Intex pool 10'x30" 1018.0 gal
    Jul 2014
    Oklahoma
    Default Intex pool 10'x30" 1018.0 gal
    Second year with it! Last year i could not find anything on how to take care of my pool! This year i found this form hoping it will help me when i finally set the pool up. Last year i had HTH 6-way test strips and i could never get a reading from anything everything stayed like it did before putting test strips in. I was using chlorine tablets in my floater thing and i had some other chemicals i threw in list of stuff i have HTH stabilizer and conditioner balance 1, HTH 1" chlorinating tablets stabilizing 2, HTH super algae guard prevent algae 4, HTH shock n swim shock 3 and i used a vacuum when it started to look or feel dirty on the bottom and used a net. Also changed the filter when it started to look dirty. Just want to make sure i do a better job and do it right this year. Sounds like im going to have to go out and buy more products from reading this site then the ones i got!!
    Default Re: Intex pool 10'x30" 1018.0 gal
    We have a Super Simple Start-up Recipe that we usually suggest for small pools but just be aware that these little tiny pools like you have are even harder to maintain than a bigger pool. Read more info here and pay particular attention to post #4 in the thread: http://pool9.net/ssr/
    Welcome to the Pool Forum!
    (Until you registration is completed, you won't be able to see the rest of the forum while you are logged in. So, copy that link and then paste it into a browser window after you log out.)
  1. Our First Pool -- Intex 9 x 12
    By BlackQueen40 in forum Intex-type Pool Setup & Operations
    Last Post: 06-28-2014, 05:58 PM
  2. Need help Intex pool
    By sew1991 in forum --cleanup--
    Last Post: 06-28-2014, 01:26 PM
  3. Need HELP! with new Intex pool
    By JimmyFW1 in forum Pool Chemistry for Intex-type Pools
    Last Post: 05-17-2014, 06:41 PM
  4. intex pool
    By kimberlysl2 in forum Intex-type Pool Setup & Operations
    Last Post: 04-29-2012, 11:15 PM
  5. New Intex Pool
    By archdiane in forum Pool Chemicals & Pool Water Problems
    Last Post: 07-06-2006, 11:49 AM
