Results 1 to 10 of 16
Thread: "Green" Owner with a Green Pool
    Jul 2014
    South Bend, IN
    Default Re: "Green" Owner with a Green Pool
    The pump I have is a Dynamo 340210
    pH: >7.8 (it was more pink than the 7.8 rating)
    Chlorine: <.5 (it was clear, no hint of yellow at all)
    Alkalinity: 60 ppm
    Hardness: >600ppm (I stopped adding drops after 12)
    Stabilizer: 0 (the black dot never disappeared)
    I know the pH is too high, and I probably need to add muriatic acid, but with the alkalinity being too low, I should add baking soda. Those seem to be contradictory to each other. Because the pH is too high, should I just focus on getting THAT right, and then deal with the alkalinity later?
    I'm still finding a LOT of stuff in the initial filter bucket (attached to the pool, before it actually GETS to the filter). Should I not worry about anything else until that is clear when I check it? I plan on getting the vacuum out this afternoon, to see if that helps at all with anything (and I know the pool needs it).
    Go ahead and use some muriatic acid to lower the pH some. But, please read this page first:> http://pool9.net/muriatic/
    Don't worry about the alk for now. Actually, it is not a problem right where it is unless your pH starts bouncing around. With the high CH, you'll want to keep pH and TA on the low end anyways.
    What is your source of fill water that has hardness that high? OR, are you using shock that has calcium in it? What are the ingredients of the shock you are using? What did you use last year as your source of chlorine? For now, just use bleach.
    What is the wall height of your pool? Do you have a dug out deeper middle section? I'm a little skeptical about a 4.5ft deep AG pool.
    What kind of test kit did you buy? Does it have an OTO chlorine test (yellow drops) or a DPD chlorine test (match to a pink comparator?)
    Try and scoop out as much debris as you can. Answer the questions I asked above and then I'll better be able to make suggestions for how much bleach to add. Walmart's generic 8.25% unscented bleach is fine and what most of us use. While you are there, also get a jug of distilled water.
    Repost with the answers to the questions and then someone here can help you go from there.
    Welcome to the Pool Forum!
    (Until you registration is completed, you won't be able to see the rest of the forum while you are logged in. So, copy that link and then paste it into a browser window after you log out.)
    Jul 2014
    South Bend, IN
    I am using well water. The ingredients on the shock I am using are 12.5% Sodium Hypochlorite, 87.5% Inert Ingredients. Last year, I used 3" chlorine tabs (don't remember the brand and no longer have the container), HTC super shock bags, and the same shok that I listed the ingredients above.
    I checked the wall height in one area and it is 4ft. The pool came with the house, and I think that the previous owners that installed it may not have installed it on level ground, as there are some spots where it seems to come up higher on me than others when I'm outside the pool (I'm 5ft 3in).
    The test kit I bought is a Kokido 6-way Swimming Pool Test Kit, which measures pH, Chlorine/Bromine, Alkalinity, Hardness, and Stabilizer. The chlorine test is marked as OTO. I found a listing for it on Amazon (currently unavailable, but you can see what came in the kit): http://www.amazon.com/Kokido-6-Way-S...pr_product_top
    I need to go to Walmart this afternoon anyway. How many gallons of bleach should I get? And just one of the distilled water?
    Ok. Your shock is simply strong bleach. Bleach is 8.25% sodium hypochlorite. So, you can use what you have. I estimate your volume to be about 13,000 gallons. So, each of those gallons that you have (assuming that they really are 12.5% and the strength hasn't degraded although that is common) will add about 9.5ppm of chlorine.
    This evening, go ahead and add 2 gallons of the shock. This is higher than your kit's chlorine test can measure but you can use the chart at this link to interpret off the chart OTO results:> http://pool9.net/oto-chart/
    It isn't going to stay that high for long so you'll need to continue to add shock to try and keep your chlorine in the dark yellow range. If your pool is as swampy as you say, you may find that by morning, you have lost a lot of the chlorine. That is good. It will mean that is has been busy overnight killing stuff. You may need to add chlorine a couple of times per day although adding it in the evening is the best time because it allows all the chlorine to go to work oxidizing stuff with none of it being lost to the sun. However, in a pool with low CYA like yours, you may have to also add some during the day to keep some chlorine in there.
    Once you get your pool cleaned up, you'll need to add some CYA. You can either do so by using some dichlor for awhile or by just adding some CYA separately. A lot of places are selling blended dichlor which you don't want. IF there is a Sam's Club near you, they sell some good dichlor that you can use. If you buy their 1 lb packs, any that you don't use can be saved until next season. http://www.samsclub.com/sams/shop/pr...oductId=108822 If you would rather just add some CYA separately, let us know and we can help you figure out how much to buy and add.
    Since you have a CYA test in your kit, instead of ordering a K2006 kit, if you will just order a K1515 add-on kit, it will give you the chlorine test that your kit doesn't have that allows you to measure chlorine readings past 5ppm. It is also available through that same link that I posted above.
    Just get one jug of distilled water. No need to buy bleach today although once your 5 gallons are gone, you'll either want to buy bleach or buy more of the shock. Figure out which one is the better buy. I will tell you this, though. Higher concentrations of sodium hypochlorite that are often sold at pool stores have often degraded and are therefore not really the strength the label says. Walmart's generic bleach has a high turnover rate and is more likely to be fresh.
    By the way, don't run the CYA test anymore for now. It isn't going to change unless you start using a stabilized form of chlorine (which means it has CYA in it) or unless you add some directly. No reason to waste the reagent.
    I'd be curious to have you do a calcium hardness test on a well water sample.
    Keep us posted how things are going and if you have more questions, we'll be here!
    Jul 2014
    South Bend, IN
    I checked the chemicals again this morning before I left for work. The chlorine test was registering around 25ppm, and the pH was between 7.6 and 7.8 (closer to the 7.8 pink). I added some pH Down before leaving for work, and left the pump running all day. The basket is looking MUCH better each time that I check the pool, and I try to spend at least 30 minutes out there with the net each day, cleaning up what I can. I imagine that I'll get the vacuum out tonight, depending on how things look when I get home.
    I don't think I've ever been so happy to see the chlorine test come back orange!
    When the chlorine is above 5ppm with your kit (above 10ppm with Taylor kits), you'll get falsely high pH results. Retest pH this evening by mixing equal parts of pool water and distilled water and then run the pH test as normal. (This is what the gallon of distilled water that I suggested you buy will be used for.)
    Jul 2014
    South Bend, IN
    I just got home and tested the chlorine levels. I'm back down to less than 1ppm. The pool is still murky looking too. Part of me almost wonders if I should drain the pool completely, and start from scratch.
  1. Replies: 8
    Last Post: 08-04-2012, 11:43 PM
  2. Green, green, green and running out of patience.
    By marciastz in forum Dealing with Algae & Slime
    Last Post: 06-12-2012, 12:51 PM
  3. Cloudy Green well water pool-first time pool owner
    By jeffd in forum Pool Chemistry for Intex-type Pools
    Last Post: 06-12-2012, 08:44 AM
  4. Just Another Owner of a Green Abyss
    By markintosh in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 05-29-2011, 05:59 PM
  5. green water or green liner?
    By denanbob in forum Dealing with Algae & Slime
    Last Post: 05-26-2011, 12:16 PM
