Thread: having pump problems
    Jul 2014
    indiana
    Default having pump problems
    we have a hayward power flo 1 hp pump and i am wanting to make sure i can get the right motor berrings for it.. so i tried to take it apart to get the right numbers of the berring but the impeller is very stuburn and wont give.. i have tried the screwdiver in the back and even used locking pliers on the shaft between the motor and the pump housing.. does anyone know a trick to get the impeller off. and does anyone know the exact berrings i need for the motor its a hayward power flo 1580 1hp and the sticker on the motor has the number sp 1510z1xbc on the lable....bill
    BigDave's Avatar
    Default Re: having pump problems
    I was successful using an adjustable wrench on the flats on the motor end of the shaft and a strap wrench on the impeller. I'm pretty sure it's threaded backwards.
    Sorry this is so late, I just now saw your post.
  1. Pump problems . . .or timer problems?
    By bschooly in forum Pool Equipment & Operations
    Last Post: 05-08-2014, 12:36 AM
  2. Pump problems...
    By Bearsbee in forum Pool Equipment & Operations
    Last Post: 08-16-2012, 12:53 AM
  3. Pump Problems
    By sgreiner1011 in forum Pool Equipment & Operations
    Last Post: 02-28-2012, 12:21 PM
  4. Help! Pump problems
    By kevinm in forum Pool Equipment & Operations
    Last Post: 05-17-2008, 04:56 PM
  5. Pump problems... Hard to prime and air in the pump lines
    By tinyprotagonist in forum Pool Equipment & Operations
    Last Post: 06-29-2006, 11:38 PM
