Results 1 to 8 of 8
Thread: While waiting?
    Jul 2014
    Oklahoma
    Default Re: While waiting?
    Thanks for the reply. You have eased my mind and enabled me to get some sleep this weekend. I have a 5600 gallon pool, so I suppose a 1/2 gallon of bleach per day should be enough? Thx again
    In a 5600 gallon pool, half of a 121-oz jug of 8.25% bleach will add about 7ppm of chlorine. You may find that you need to add some morning and evening. Pools with no CYA lose chlorine fast. Just do a quick check a couple of times per day and if the chlorine is getting too low, just add a little bleach. Just make sure you keep a reading. I was able to only add bleach once per day when we had no power but I had CYA in my pool. You don't. So, you'll just to have to keep an eye on it. It will be fine.
    Jul 2014
    Oklahoma
    what is the best way to check it. With those test strips?
    No, not test strips. We call them 'guess strips' for a reason. The test kit that we think is by far the best is the Taylor K2006 or 2006C (better buy) that I mentioned in my previous post. But, in the meantime, go to Walmart and get an OTO/Phenol Red kit (yellow and red drops). Use it to test the water. It will only read to 5ppm which will be ok for now. But, do order the K2006 kit. It tests everything you need to test and will make your pool maintenance so much easier.
    (Until you registration is completed, you won't be able to see the rest of the forum while you are logged in. So, copy that link and then paste it into a browser window after you log out.)
    Jul 2014
    Oklahoma
    It is nice to have such knowledgeable people to get info from. This is a great site. Thanks again.
    Quote Originally Posted by Wilbarger View Post
    Thanks! We think so, too!
  1. Chlorine while waiting for CYA level to come up
    By vitaminddd in forum Pool Chemistry for Intex-type Pools
    Last Post: 07-24-2013, 03:52 PM
  2. Now just a waiting game!
    By Budlight592 in forum Above-Ground Pool Construction & Repair
    Last Post: 07-14-2012, 11:10 AM
  3. waiting for aquarite...
    By BND in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 04-25-2007, 08:59 PM
  4. Anxiously waiting
    By newtopools in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-08-2006, 11:01 PM
  5. Do I need to shock? Waiting for Ben's kit.
    By ShelleyAnn in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-04-2006, 12:10 AM
