Thread: Rain topping off Intex 15x48 pool...
    Jun 2014
    New York
    Default Rain topping off Intex 15x48 pool...
    Rained a few inches in NYC last two days. Water level is nearing the top of my Intex 15x48 metal frame pool. What should I do, if anything? Empty a little? Leave it alone? Will the ph, FC, etc. be effected? Probably a silly question, but wanted to ask anyway.
    BigDave's Avatar
    Default Re: Rain topping off Intex 15x48 pool...
    If the pool spills over, you'll lose CYA. My pH usually goes down a bit when it rains - no need to adjust unless it gets to 7.0 or lower. You'll probably use a little less chlorine than normal with no swimmers and cloudy skies.
    Aug 2013
    Massachusetts
    I have the same pool, and we just leave it. Our bathers splash and jump around enough that the splashover cures that issue. I use a SWCG, so I watch carefully my salt ppm level with the added water. Losing pool water, then it being filled with rain water, dilutes things out a bit at times. I also try to maintain a constant CYA level.
    4.5k gal 15 x 48 Intex pool; PF=26
  1. 15x48 pool pump help
    By cdawg in forum Pool Equipment & Operations
    Last Post: 08-11-2013, 01:58 PM
  2. Intex 15x48 with algae
    By DSeese in forum Pool Chemistry for Intex-type Pools
    Last Post: 08-13-2012, 02:19 PM
  3. 10 inches of RAIN in pool, now what??
    By poolmom06 in forum General Interest
    Last Post: 07-05-2007, 03:31 PM
  4. Topping off water level
    By pool newby in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 05-22-2007, 11:59 AM
  5. Topping off a large sand filter
    By framcus in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 05-09-2007, 10:06 PM
