Help
Remember Me?
Forum
FAQ
Calendar
Forum Actions
Mark Forums Read
Quick Links
View Forum Leaders
What's New?
Advanced Search
Forum
Odds-n-Ends (P)
Clearance
--cleanup--
Trichlor
If this is your first visit, be sure to check out the
FAQ
by clicking the link above. You may have to
register
before you can post: click the register link above to proceed. To start viewing messages, select the forum that you want to visit from the selection below.
Results 1 to 3 of 3
Thread:
Trichlor
Thread Tools
Show Printable Version
Email this Page…
Subscribe to this Thread…
Display
Switch to Linear Mode
Switch to Hybrid Mode
Threaded Mode
Threaded View
07-14-2014
09:14 PM
#1
furray
View Profile
View Forum Posts
--trial user--
Jul 2014
alabama
Trichlor
I read not to use Trichlor, why?
Quick Navigation
--cleanup--
Top
Site Areas
Settings
Private Messages
Subscriptions
Who's Online
Search Forums
Forums Home
Forums
Ben's Corner
Notes and News from the PoolDoc
Forum Q & A
-- Subscriber Posts --
Pool Water: Treatment, Testing & Problems (P)
Pool Chemistry for Intex-type Pools
Testing and Adjusting Pool Water Chemistry
Using Chlorine and Chlorinating Chemicals
Salt Generators (SWCG) & other Chlorine Feeders
Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
Dealing with Alkalinity and Calcium
Dealing with Algae & Slime
Pool Chemicals & Pool Water Problems
DPD-FAS based testing
Chlorine Alternatives: UV, Ozone, Baquacil (PHMB), etc
Pool Construction, Equipment, Operations, Seasonal Care (P)
Intex-type Pool Setup & Operations
In-Ground Pool Construction and Repair
Above-Ground Pool Construction & Repair
Pool Equipment & Operations
Pool Startup, Shutdown, & Winter Operation
Pool Cleaning: Manual or Automatic
Pool Electronics
Pools, Pets and Creepy Critters
Odds-n-Ends (P)
Photo Gallery
Clearance
--cleanup--
The China Shop
General Interest
Practice Forum
PoolSolution Archive
The Hall of Shame
Hello! Leaky pump problem
Pool Pilot Digital - Check/Clean Cell
Trichlor = How much CYA?
By myLABSpool in forum Using Chlorine and Chlorinating Chemicals
4
Last Post:
06-09-2012,
08:23 AM
CYA in Trichlor?
By jhm in forum Using Chlorine and Chlorinating Chemicals
11
Last Post:
06-22-2010,
04:06 PM
94% Trichlor?
By rhosk in forum Using Chlorine and Chlorinating Chemicals
13
Last Post:
06-22-2010,
10:39 AM
trichlor and ph
By itjustrixie in forum Using Chlorine and Chlorinating Chemicals
2
Last Post:
06-03-2007,
02:20 PM
CYA very low, however I use trichlor
By nicole12 in forum Testing and Adjusting Pool Water Chemistry
3
Last Post:
05-31-2006,
07:13 PM
Digg
del.icio.us
StumbleUpon
Google
You
may not
post new threads
You
may not
post replies
You
may not
post attachments
You
may not
edit your posts
BB code
is
On
Smilies
are
On
[IMG]
code is
On
HTML code is
Off
Forum Rules
