$400 a month would make me fill it in too.
1,2) yep, gotta fix leaks.
3) Sounds like a shaft seal. Not too hard if you're handy - you tube has videos. Important to keep the seal mating faces clean (don't touch) and don't get any lube on the piece of the seal that grips the shaft.
4) May be if you get the leaks fixed, you won't need a fill system.
5) If you put a couple vitamin C tablets on it and the stain lifts, it's metal. If you put some pieces of a trichlor tab on the stain and it lifts, it's organic.
Welcome, let us know how it's going.
That's All Folks!
