Results 1 to 10 of 20
Thread: Help with sizing new filter
    TomC is offline PF Supporter Thread Analyst TomC 0
    New York
    Default Help with sizing new filter
    My brother has an above ground oval pool, which is 15' x 30' x 48". He currently has a 1.5 HP Hayward pump and a broken DE filter. He is buying a new sand filter and needs to know the appropriate size. He is not averse to buying a new pump too, and emailed me this combo and wanted to know if it's ok for his pool.
    http://www.amazon.com/dp/B000EVNZLQ/..._it8Wtb13MV2A7
    Any and all advice appreciated.
    Tom
    20'x42' L' 41K gal IG vinyl pool; trichlor feeder, bleach; Pentair 420 cartridge filter; Pentair Whisperflo 1.5hp 2 speed pump; hrs; TF-100, CYA test; city;PF:2.9
    New York
    Default Re: Help with sizing new filter
    Is there a chart or table for filter/pump sizing that someone could point me to?
    Tom
    New York
    Thanks Watermom. He's going to get a pump/filter combo. What do you think of the combo in the link?
    Tom
    OOPS. I didn't notice that it was a pump/filter combo when I looked at that link a few minutes ago. I looked too quickly and only saw the filter size.
    See what Ben thinks. But, if it were me, I'd buy a bigger filter than the one in that combo. I've asked Ben to pop in to this thread and offer his opinion.
    The 1.5 Hp pump is probably up-rated, meaning it is equivalent of 3/4hp full-rated pump, roughly, so not as seriously over-sized as a full-rated pump would be.
    New York
    Thanks for the help guys
    Tom
    Aug 2012
    San Jose, California
    How to tell if pump is uprated or full rated?
    12'x24' 8.3K* gal Intex AG vinyl pool; Intex SWCG CS20110 .92W pump & 110# sand filter combo; HTH 6-way stick; K2006; utility water; PF:14.5
    Usually the flow rates tell you. Hayward above-ground pumps (and this is one) are generally up-rated, but we have folks here who are more knowledgeable about such details than me. Hayward's combos do tend to match the pump and the filter, but just barely. Ball-parking it, I'd sooner see you get that pump with the next size up filter--the 200# version (T210?) and you'd be sure the filter is adequate. I don't know why Hayward doesn't match them that way, and the 150# sand filter with the 3/4hp uprated pump. I have the 200# with the 1hp 2speed Superpump and it's adequate at full speed, but I've always wished I had gotten the 250# (the Superpump 1hp is more powerful than the pump you're considering).
    Still, a Hayward combo set should have a warranty on the whole thing.
    Aug 2012
    Hi Carl,
    Let me know if I should post this on new thread.
    After 2 weeks out of town, pool is now slightly green from the vinyl everywhere due to pump working very poorly. I added a gallon of chlorox bleach and 4 cups of kemtek dichloro last night. Before adding, I've tried to vac the green algaes but pump kept beeping with low flow and self shut offed shortly. I have noticed that the pump had been losing the flow rate after the second season and now it's completely useless.
    My current Intek has pump with SWG built in. Is it possible to buy just the pump connect it in series before the Intel so the SWG would still work. .
    The intek worked OK when new but still very weak when adding 25 feet vac hose - it would beep for low flo and shutdown shortly. Vac hose attaching to intek skimmer is likely 1 inch....
    I'd like a 2 speed pump and use hi speed for vac.
    Please advise on my disaster situation?
  1. Filter sizing?
    By stlbill in forum Pool Equipment & Operations
    Last Post: 06-20-2013, 01:19 PM
  2. Sizing replacement filter
    By Vegas in forum --cleanup--
    Last Post: 12-19-2012, 03:42 AM
  3. Pump and filter sizing
    By wsommariva in forum Pool Equipment & Operations
    Last Post: 05-23-2011, 12:37 PM
  4. DE filter sizing
    By eljefe281 in forum In-Ground Pool Construction and Repair
    Last Post: 05-04-2007, 01:04 PM
  5. New Filter sizing help please?
    By azhobbs in forum Pool Equipment & Operations
    Last Post: 10-25-2006, 09:52 PM
