Thread: cloudy water
    Jul 2014
    ohio
    Default cloudy water
    My pool is a walmart type above ground pop up pool with a PVC frame, with a sand filter. (I just learned about the BBB method & now understand why I am having problems but need help correcting it. I'm hoping I'm on the right track). The water turned green, and the lady at the pool store advised me to double the amount of shock & swim, & when that didn't work to use a very small amount of algecide. It sort of worked but now the water is a cloudy blue. The pH was so low it was off the chart but after reading about BBB I have effectively raised the pH using 20 mule a borax, but I'm not sure of what step to take next to get my water clear again? . I really need to correct without draining & starting over if possible. Please help
    Default Re: cloudy water
    Hi and welcome to the Pool Forum!
    Tell us exactly what all you have put in the pool. We need to know the ingredients. Many algaecides cause more problems than they solve so we are pretty suspicious of most of them.
    Also, tell us the volume of your pool and the size (hp) of your pump and size of your sand filter (how many pounds of sand it holds).
    Do you have a drops-based test kit? We will need some numbers, too.
  1. Cloudy water
    By Vlmac55 in forum Dealing with Algae & Slime
    Last Post: 07-19-2012, 08:31 PM
  2. cloudy water
    By twerner in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-01-2011, 05:19 PM
  3. Cloudy Water - I think
    By Skillset in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 09-28-2007, 10:00 AM
  4. Cloudy Water & Water Behind Liner
    By cschnurr in forum Dealing with Algae & Slime
    Last Post: 09-19-2007, 09:04 PM
  5. Cloudy water
    By chili in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-25-2007, 10:17 PM
