Thread: New house and first pool
    Jul 2014
    florida/tenn
    Default Re: New house and first pool
    Thanks Doc
    I'm in Henderson Tn or the pool is..
    I'm headed up there in a few weeks and would like some advise, I was planning on cleaning out all the leaves. I also was going to hook up a extra pool pump I got for a about ground and start filtering the water.. good Idea? or should I just drain it and refill?
    dennis
    What is your volume? That's a lot of water to throw out. You can probably clean it up with a lot of bleach. Scoop out as much organic stuff as you can.
    Go ahead and order a Taylor K2006 or 2006C (better buy) test kit to day if you can so you will get it soon. Not available locally but you can get it through this link:> http://pool9.net/tk/
    In the meantime, go to Walmart and pick up a cheap OTO/Phenol Red (yellow and red drops) kit. Aim to keep the chlorine in the dark yellow range. http://pool9.net/oto-chart/
    You'll probably find that you have to add chlorine a couple of times per day.
    Run your pump 24/7 while you are clearing it. What size is the pump? What kind and size is the filter?
    BigDave's Avatar
    Default
    For what purpose?
    If it's a 'swamped-up' concrete pool, and the ground is dry enough to allow you to drain safely, I'd drain it, pressure wash it, and refill.
    Clearing a swamp is a total PITA, even with the best pump and filter.
    CAUTION: Keep in mind that you can NOT drain a vinyl pool, and often can not drain a fiberglass pool, without causing serious damage.
  1. Help !!!! House came with pool....now what??
    By homeschoolmom in forum Pool Chemicals & Pool Water Problems
    Last Post: 06-10-2014, 06:50 PM
  2. New House, Old Pool
    By almoagnadna in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 04-25-2012, 01:54 PM
  3. New House Old Pool
    By chemi19 in forum Pool Cleaning: Manual or Automatic
    Last Post: 11-14-2011, 01:15 PM
  4. New house with a pool
    By Big Mike in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-24-2007, 10:21 PM
  5. Pool vs House
    By cajunfla in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-03-2006, 01:41 PM
