Results 1 to 10 of 12
Thread: cloudy and still balancing metals
    mrszaff is offline Registered+ Thread Analyst mrszaff 0
    May 2010
    New York
    Unhappy cloudy and still balancing metals
    TODAY'S NUMBERS:
    FC 2.0
    cc .5
    PH 7
    ALK 60
    CYA 80
    Hi, and thank you in advance!
    The water is not green, but it is very cloudy and I cannot see the drain, the shallow end is starting to stain, but I can deal with that after the cloud is gone. I have Culator bags in the baskets, Ascorbic acid in the pantry and metal free on hand.
    Water turned cloudy 48 hours ago, I added polyquot 60 and also 3 gallons bleach slowly over 2 days since it was almost 0, The ph was at 6 so I have been adding borax .
    yesterday I also added a clarifier but its still cloudy. filter running 24/7
    Should I keep adding bleach ? borax?
    16x32' rectangle 19K gal IG vinyl pool; bbb; jacuzzi sand filter; jacuzzi pump; 8hrs; Taylor 2000; utility water; summer: none; winter: vinyl / water bags; ; PF:6.3
    May 2014
    Plano, TX
    Default Re: cloudy and still balancing metals... help!
    I'm not the expert by any means, but,,,
    With CYA at 80, you need to keep your FC above 5ppm ALWAYS. This explains why.
    http://pool9.net/cl-cya/
    More borax is in order, pH should be 7.2 - 7.8.
    Since your water is cloudy and you said FC was around zero, you very likely have an impending algae bloom. If it were me, I'd run the FC up to 20 or 25 ppm (with bleach or liquid chlorine) and keep it there until 24 hrs after,
    1. There is less than 1ppm loss of FC between sundown and sun rise.
    2. There is no more than .5ppm CC present
    3. There is no hint of green in the water.
    There are lots of reasons, other than algae bloom, that water turns cloudy and it is entirely possible that algae is not the problem. Bleach (liquid chlorine) is the least likely to complicate your issue if algae isn't the problem, and a little time will solve the high FC issue.
    Good luck
    Pappy
    May 2010
    New York
    thank you, the water is clear today. I can see the drain! I now have to remove the metal stain on the liner, I will follow the process posted thanks!
    I'm not the metal expert either but if you add a large amount of bleach and your pool does NOT turn green or some other color, but, instead, reacts as we normally expect with an algae bloom, you probably don't have serious metal problem.
    When you do have a metal problem the metal remover first must dissolve and suspend the metal before you can raise your FC level--or it goes jello-green.
    Have you posted the results of metal tests here? If you haven't done the tests, the local pool store can probably do that...they'll try to sell you stuff, including useless calcium for your VINYL pool--but you don't have to buy it.
    May 2010
    New York
    Unhappy Re: cloudy and still balancing metals... help!
    pool store wont test for metal , but I just added polyquat to prevent algae and ascorbic acid and the stain lifted. I put the sequestering agent in next with culator bags and skim socks in baskets. Then, my chlorine dropped to almost nothing so i will adjust it and ph levels tomorrow after ascorbic acid is dissolved, that is how I understand the directions posted in the sticky about removing stains with ascorbic acid. Please let me know if that's ok... This has been an issue for the last few years, perhaps I should drain the pool at the end of the season, but I dont know where the metal comes from. We are not on well water...
    Is it safe to swim or should we wait till tomorrow?
    PS After adding sequestering agent and running filer for 30 min the water is cloudy, is that from the ascorbic acid or metal free sequestering agent? it was fine all morning when I had it on circulate,now its cloudy.
    May 2010
    New York
    http://cdn.shopify.com/s/files/1/009...g?v=1383262547
    natural chemistry metal free
    This is the product I used after the ascorbic acid. I can't believe I finally cleared the water with shock and got rid of the stain and now its cloudy again! No CL left in pool and ph is low, I will run test i morning but with the strips it looks lower than 7
  1. Help with balancing pool
    By Dohcvtec in forum Pool Chemistry for Intex-type Pools
    Last Post: 07-25-2013, 07:30 AM
  2. Help with balancing my water - which do I address first?
    By derekb41 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 05-22-2012, 11:36 PM
  3. Re-balancing after switching to Chlorine
    By GeneNTN in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-06-2011, 01:48 PM
  4. balancing levels
    By purplegirl in forum Pool Chemicals & Pool Water Problems
    Last Post: 07-04-2010, 11:16 AM
  5. Balancing chem after sequasol
    By smokeygrl in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 08-13-2006, 12:18 AM
