Help
Remember Me?
Forum
FAQ
Calendar
Forum Actions
Mark Forums Read
Quick Links
View Forum Leaders
What's New?
Advanced Search
Forum
should algea preventer be used if none present
FAQ
register
Thread:
Thread Tools
Show Printable Version
Email this Page…
Subscribe to this Thread…
Display
Switch to Linear Mode
Switch to Hybrid Mode
Threaded Mode
Threaded View
07-10-2014
04:43 PM
#5
Watermom
View Profile
View Forum Posts
SuperMod Emeritus
Quark Inspector
Re: should algea preventer be used if none present
It is certainly fine to use it. But, not necessary. I never use it in my pool.
Quick Navigation
Top
Site Areas
Settings
Private Messages
Subscriptions
Who's Online
Search Forums
Forums Home
Forums
Ben's Corner
Forum Q & A
-- Subscriber Posts --
Dealing with Algae & Slime
DPD-FAS based testing
Pool Equipment & Operations
Pool Electronics
Odds-n-Ends (P)
Photo Gallery
Clearance
--cleanup--
The China Shop
General Interest
Practice Forum
PoolSolution Archive
The Hall of Shame
Adjusting pH and TA
CYA test interpretation
No chlorine present after winter
By Jacob99 in forum Pool Startup, Shutdown, & Winter Operation
1
Last Post:
04-21-2014,
07:30 PM
New Home/Pool Owner. Cloudy/Algae Present, Have Readings, will bleach...
By DallasGuy in forum Dealing with Algae & Slime
2
Last Post:
08-25-2012,
01:56 PM
Close with algea??
By jagwire22 in forum Pool Startup, Shutdown, & Winter Operation
6
Last Post:
10-21-2010,
06:36 AM
CYA present in sodium dichlor?
By poolgal13 in forum Using Chlorine and Chlorinating Chemicals
6
Last Post:
06-14-2006,
01:33 PM
Algea Blowing Out Jet
By godstreasures1 in forum Above-Ground Pool Construction & Repair
3
Last Post:
05-15-2006,
07:57 AM
Digg
del.icio.us
StumbleUpon
Google
You
may not
post new threads
You
may not
post replies
You
may not
post attachments
You
may not
edit your posts
BB code
is
On
Smilies
are
On
[IMG]
code is
On
HTML code is
Off
