Thread: Pipework confusion
    Jul 2014
    Cramerton, NC
    Default Pipework confusion
    Hi All
    Looking for some advice from some pool experts.
    Just purchased a home with pool and have been trying to get my pool dialed in. I am doing the maintenance myself after firing an incompetent pool company, (which is another long story involving green pools and filters at 38psi.)
    Recently a couple of sections of the above ground plumbing at the equipment has sprung a leak. The first leak is within the gas water heater, which will be simple enough to bypass, as I have no use for the heater.
    The latest leak is on a pipe I have absolutely no idea of why it exists. This is where I need your help.
    This pipe tees off from the main pump and goes directly to the returns, bypassing the filters and chlorinator.
    For some reason I cannot post pictures to the forum, but hopefully these link through ok.
    https://www.flickr.com/photos/125327010@N08/
    Question is, can I simply remove this line and cap it off, or does it serve a purpose.
    BigDave's Avatar
    Default Re: Pipework confusion
    It looks to me like the supply lie for the pressure side cleaner booster pump.
  1. Pool test kit confusion - help!
    By SurfaceDreamer in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 05-22-2012, 01:00 AM
  2. Chlorine confusion
    By GregP in forum Pool Chemicals & Pool Water Problems
    Last Post: 04-18-2012, 07:33 AM
  3. Phosphate confusion
    By aguaguy in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 08-24-2006, 01:43 PM
  4. Phosphate confusion
    By aguaguy in forum Dealing with Algae & Slime
    Last Post: 08-23-2006, 08:22 PM
  5. Help.....Im in conversion confusion
    By chlorinebound in forum Chlorine Alternatives: UV, Ozone, Baquacil (PHMB), etc
    Last Post: 08-05-2006, 12:17 PM
