Results 1 to 10 of 17
Thread: Need help getting my pool right for birthday party this saturday
    Mar 2014
    South Carolina
    Default Need help getting my pool right for birthday party this saturday
    Hello all, I joined a few months back and read alot of helpful info to get my pool up and going. Just wanted to stop in and say hello
    I have a small 15ft wide intex pool with cartridge filter.I have a 5 way test kit by HTH. I have been able to keep my pool water nice and clean by using the hth 5 in1 or 6 in 1 bags I forget that part. Keeping chlorine tabs in my skimmer. Well I got sick and couldnt do any maintenance to the pool for a week. There was some algae at the bottom of one side of the pool. Also my water was a about 4 inches below normal. So I added more water, waited checked my Ph balance added baking soda. waited a couple hours then used a little shock to get he levels right. Next day the whole pool was green. So I put in some HTH algaecide. It started to clear up after a day. So I shocked it to help the process of killing the algae. Now I have a cloudy pool which I assume is dead algae. How can I get the pool clear by this saturday july 12th? Im having a birthday party for my kids and need help please.
    Also, I think what caused the algae to get worse was when I added the water. Our county get water from a local lake. People have been complaining about the water because it smells and tastes funny. Yet they tell us it meets all safety standards and is safe to drink. They said it was due to whatever this is: geosmin and mib. Mib is an abbreviation for something. From what I read its either a compund or toxin from algae blooms in our water. There were so many complaints they installed something to add carbon or something to the water to neutralize these toxins or whatever. Anyways, the water still taste and smells bad. I just wonder if thats why the algae got bad really fast when it was very little the day before.
    Thanks in advance for your help. Praying I dont have to drain the pool because of this.
    (Note from moderator: Two posts waiting in the queue were combined.)
    Jul 2014
    NC
    Default Re: Need help getting my pool right for birthday party this saturday
    go to the store and buy some 8.25% Chlorox Concentrated liquid bleach. At Sams club it was about $12 for a box of three. Get about 4 boxes or 12 bottles. Then get 60% Algecide. one bottle will do but get two. It should say in the contents, "poly.........".
    DON'T put it in yet! Brush the sides (at least twice) and the entire bottom. Backflush your filter until the glass is clean and then twice as long.
    When it is dark, NOT BEFORE, put in the algecide, twice what is on the label. Wait 45 minutes. put in enough bleach to raise the level to 20ppm FREE chlorine.
    In the morning you WILL have dead alge in the bottom of the pool but it will be brown. Sweep the pool to waste and add water as you are sweeping.
    Brush again. Wait until dark again, repeat algicide and bleach but half as much. May need to brush again on Friday. A lot of work BUT....this works. Don't let anyone in the pool while you are doing this as the chlorine level will be too high.
    Good Luck.
    BigDave's Avatar
    mrkim is giving you advice that is not what you'd usually get on this site.
    Sadly, I can't give you a solution that I think will work in time for the weekend besides drain and refill.
    If you do refill, please consider startting up with the Super Simple Recipie (http://pool9.net/ssr/).
    The best tips I can give a new pool owner:
    1) Order a Taylor K-2006 test kit. Not available in stores. Buy it through this page: http://pool9.net/tk/ and Pool Forum gets some coin to keep the lights on.
    2) Read all you can here especially the stickied threads in the testing and chlorinating forums also read the guides at poolsolutions.com. Pay special attention to the Best Guess Chlorine Chart page as it describes the basis for the safe, efficient, and effective method of pool care taught here.
    Note: as a trial user you'll have to log out to see the other parts of the forum so copy the URLs, log out, then paste 'em in your browser.
    Good luck and welcome!
    Let us know how it's going.
    Mar 2014
    South Carolina
    thanks for the reply. i took a water sample to the pool store knowing i was gonna get charged out the butt but its my last resort. their results were
    free chlorine 6.2ppm
    total chlorine 8.2ppm
    combined chlorine 2.0ppm
    ph 7.8
    hardness 20ppm
    alkalinity 177ppm
    cyanuric acid 54ppm
    copper 0
    iron 0
    nitrate 7ppm
    phosphate 100 ppb
    total dissolved solids 830 ppm
    they recommended i use 1 lb of ph minus
    wait an hour add 10 lbs of calcium
    wait an hour and add 2 pounds of shock calcium hypochlorite . I've been using dichlor.
    also they have my pool posted as 4,500 gallons i thought my 15 ft intex was 5500 gallons.
    im pretty sure i went through this once last year and they sold.me the same stuff and it worked and i was able to keep other clean the rest of the year with dichlor, tablets and baking soda. they said it would be safe to swim in tomorrow. boy i hope so
    You need to be able to test your own water. Order a Taylor K2006 or 2006C (better buy). Not available locally but you can get it through this link:> http://pool9.net/tk/
    In the meantime, go to Walmart and see if they have the HTH 6-Way drops-based kit (no test strips!) and get that. If they don't, get an OTO/Phenol Red kit (yellow and red drops) instead. Use it to test and then post your numbers. Also while you are at WallyWorld, get several jugs of their generic 8.25% bleach and a gallon of distilled water. Test your numbers and see where they are today. You may need this chart to help you with the off the scale colors:> http://pool9.net/oto-chart/
    Your chlorine levels are based on your CYA level. Having a CC reading of 2.0 is not good. Assuming that you do have around 50ppm for CYA, you need to shock your pool up to about 15ppm. More about the CYA/Chlorine connection here:> http://pool9.net/cl-cya/
    I'd just use bleach instead of cal-hypo. In your pool, (I think more like 5000 gallons), each quart of 8.25% bleach will add about 4ppm or chlorine and each cup will add about 1ppm. You can use that as a reference for figuring out how much bleach to add.
    How does your water look?
    (Until you registration is completed, you won't be able to see the rest of the forum while you are logged in. So, copy that link and then paste it into a browser window after you log out.)
    Mar 2014
    South Carolina
    thanks for the reply. I have the walmart 6 way test kit. i only know how to check chlorine/bromine and ph. Im still trying to learn all this.
    ive been busy all week and havent had time to learn this stuff like i need to. if i only hadnt added that water and just left it a few inches low. thats what started it all id be okay for the party and then i could have went through all of this after the party. oh well, whats done is done. now im having to get everything ready for the party and fight this pool at the same time.
    when i get a few minutes im gonna read those links you sent me. in the meantime im gonna figure out how to use my 6 way test kit and get those number posted. the numbers i posted earlier from the pool store are what todays levels were about 3 hours ago.
    thanks so much for you time
  1. No free chlorine in AG pool after party
    By sue&Joy in forum Pool Chemicals & Pool Water Problems
    Last Post: 07-11-2013, 05:13 PM
  2. Cloudy Pool after a party
    By onemsmom in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-09-2013, 07:28 PM
  3. Pool party aftermath
    By Poolhouse in forum Pool Chemicals & Pool Water Problems
    Last Post: 04-16-2012, 11:41 AM
  4. Doh! Foam Party In My Pool!
    By troykristoffer in forum Dealing with Algae & Slime
    Last Post: 08-03-2006, 09:50 PM
