Results 1 to 3 of 3
Thread: Hayward DE filter leaks
    guman2 is offline ** No working email address ** guman2 0
    Default Hayward DE filter leaks
    I have a Hayward DE filter model EC-50C which has developed a leak between where the upper and lower filter housings are joined with the clamp Ass'y and spring.....I have the clamp plenty tight but there is still a small amount of leakage...Seeing the housing is plastic I don't want to break the plastic by over tighting the spring too much....Anybody ever have this problem and how did you correct this???
    markphin is offline Registered+ Thread Analyst markphin 1 star
    Default Re: Hayward DE filter leaks
    Check your o ring for wear. Also maybe some crud on the area where they come together. Disassemble clean the area well, check the o ring, if in good shape maybe lightly lube and reassemble
    IL.
    Quote Originally Posted by guman2
    My Pac Fab DE filter has this type of closure. If I don't get it lined up just right before tightening it all the way down, I get a leak. And I second the check for crud and condition of the O ring.
  1. DE leaks into pool; and filter clamp leaks elsewhere
    By Lowdown in forum Pool Equipment & Operations
    Last Post: 05-20-2012, 06:59 PM
  2. Possible to repair leaks in a Hayward DE filter?
    By CAL7 in forum Pool Equipment & Operations
    Last Post: 07-13-2008, 06:57 AM
  3. Leaks in DE filter
    By Mom2Czars in forum Above-Ground Pool Construction & Repair
    Last Post: 07-13-2007, 10:37 AM
  4. Some small leaks from filter
    By NullQwerty in forum Pool Equipment & Operations
    Last Post: 05-29-2007, 07:24 PM
  5. Pump and Filter leaks
    By Wolffe in forum Pool Equipment & Operations
    Last Post: 05-15-2007, 10:21 PM
