Results 1 to 10 of 23
Thread: Noob from OKC taking on liner install
    Jul 2014
    Oklahoma
    Default Re: Noob from OKC taking on liner install
    Thank you watermom for the link.
    My first order of business before the liner comes in is to repair the return lines. I'm planning on cutting through the concrete this evening to help me see what's below. All I know at this point is at least one of my returns leak. Behind the liner is foam and plywood.
    Apr 2014
    richmond,va
    I'd love to hear more on your progress, process, do's, do not's, etc. I plan on replacing my liner next season. The measuring guides alone on the various websites I have looked at looks like quite a task in itself. I am sure you know, but there are quite a few good videos on you tube that show the process. Good luck.
    18x34 22k gallon IG, Vinyl liner, Hayward sand filter, Hayward Chlorinator, Pentair Challenger 1hp pump, LA Spa.
    Jul 2014
    Oklahoma
    So far I have managed to line up vermiculite in the area for about 21 dollars for 4 cu ft. I also have put a pool float on order.
    I ordered a 28/28 liner and foam with some liner lock. Should be delivered next week.
    Right now I'm just a little worried about how bad the wall structure will be when I get to look at it.
    My rationale for do it myself was, "would I take 1000 to 1500 hundred dollars to have a wrinkle or two in my liner?
    May 2012
    Canada
    I had a return line leaking water behind the liner.
    Upon closer inspection I discovered that I had cracked the thread with the winter plug.
    I put a bit of silicone on the crack each spring.
    Saved digging up the cement
    Jul 2014
    Oklahoma
    Gary- I wish I could be so lucky. I actually bought a couple of rubber plugs from a leak detection website. The plugs fit a few inches beyond the threads. I was going to try and isolate the two returns but I'm afraid to do much more digging close to the pump/and filter. If I dig anymore I risk damaging the suction lines that are under the cement.
    Jul 2014
    Oklahoma
    I rented a cement saw from home Depot and cut a couple 1 1/2 foot strips out of the concrete directly over the returns. Let's just say Tim the tool man would love this tool. .... Very cool. Started digging down to the return and didn't finish last night. There are many roots from nearby bushes. I still can't see how the fitting is stabilized. So far all I can see is PVC.
    Diamond blade concrete saws are SO much better than those nasty carborundum blade saws I used in the 80's: incredibly noisy, incredibly dusty, & incredibly slow. I have a little 4" diamond circular wet saw I use occasionally.
  1. New Liner Install--Twisting Liner
    By pedsrn in forum Above-Ground Pool Construction & Repair
    Last Post: 06-01-2014, 07:25 PM
  2. Water not even with markings on liner. New liner install.
    By Gmtmsm in forum Above-Ground Pool Construction & Repair
    Last Post: 05-17-2014, 09:40 PM
  3. New poster, taking care of new vinyl liner
    By jollyreaper in forum Pool Chemicals & Pool Water Problems
    Last Post: 05-16-2014, 07:01 AM
  4. liner install help?
    By jazzbone in forum Above-Ground Pool Construction & Repair
    Last Post: 05-16-2010, 06:55 PM
  5. AG Liner Install
    By snapperbig in forum Above-Ground Pool Construction & Repair
    Last Post: 05-18-2007, 01:50 PM
