Results 1 to 10 of 45
Thread: New Intex above ground owner - Psuedomonas?
    Jul 2014
    Tennessee
    Default Re: New Intex above ground owner - Psuedomonas?
    Retested PH using 1/4c distilled and 1/4c pool water and it is close to 7.0, but a smidge lighter so it could still be somewhere in between 6.8 and 7.0. Did not do acid or base demand. I guess it's safe with CC of 1 and FC of 13 to get in there with the brush tonight or no?
    I was reading on another thread that if there is CC present the water will turn pink immediately after adding 5 drops of R-0003, but this is not the case. It only started turning a very faint hardly distinguishable pink after sitting there at least 15-20 seconds AFTER swirling a while after the very last drop of R-0003, maybe longer(I wasn't really counting). Could it be just something it does if you let it sit a while?
    11k gal 22' x 52" Intex Ultra. PF=10
    Add some Borax and bring your pH up some.
    I have a feeling that you have no more than 0.5ppm of CC. Read the test immediately.
    Jul 2014
    Tennessee
    I can add Borax tomorrow night(have to pick some up, do not have it on hand). How soon should I retest after adding the Borax and when can we swim? I DO have the Robelle PH Rise on hand, I've used it once before, weeks ago, but if you think it may have some yucky stuff in it I'll just get the Borax tomorrow. The kids have been driving me up the wall asking lol...is it okay to swim tomorrow before adding the Borax or PH rise?
    Sorry for all the questions and thank you so much again!
    Jul 2014
    Tennessee
    Just checked the PH Rise and it says that the active ingredient is "sodium carbonate" it does not list anything else. I think Pool Doc said I wouldn't have to buy the Borax since I have the PH Rise, that it is same as washing soda just more expensive? I could have misunderstood him though. Last time I used the Ph Rise it went from a PH of 7.0(pool store reading) to around 7.8(7.8 was my test strip reading), but the pool store tested it a week later and it was 7.4. I added about 2 cups then(if memory serves me correctly) so I may use just 1 cup tonight if it's ok to use and see where that takes me. I would prefer not to use Muriatic Acid to lower again it if I don't have to.
    EDITED TO ADD:
    ok, went ahead and added one cup of the Ph Rise, will test in a couple of hours and see what the results are.
    You can add borax to raise the pH to normal levels, and swim immediately.
    Jul 2014
    Tennessee
    Awesome, thanks! I went ahead and added the PH Rise(you mentioned it was the same as washing soda just more expensive?)I already had here, but will switch to using Borax when it runs out. Gonna check the Ph and see where it's at here soon and adjust as needed. Then tomorrow swim and hopefully no more rash. I'll keep an eye on the chlorine, but should I dose with Dichlor again to get the Cya up? I'm still using the tablets, but I guess they aren't adding much yet.
    Thanks again for everyone's help!
    If you have dichlor, go ahead and use it. Just remember that for every ppm of chlorine added, dichlor adds almost a ppm of CYA.
    Jul 2014
    Tennessee
    Sounds good, I'll add it tomorrow night when we're done swimming since the FC was at 13 when I tested today.
    Thanks again!
  1. New Intex Pool owner...
    By mommabeans in forum General Interest
    Last Post: 06-07-2013, 03:45 PM
  2. New Intex Pool owner...
    By mommabeans in forum --cleanup--
  3. New Intex owner from Texas
    By Rockwall in forum Pool Chemistry for Intex-type Pools
    Last Post: 08-01-2012, 03:43 PM
  4. New Intex Pool Owner and on a well.
    By virtualmech in forum Pool Chemistry for Intex-type Pools
    Last Post: 07-18-2012, 11:30 PM
  5. New Intex Pool owner
    By GeorgeMccarthy in forum Pool Chemistry for Intex-type Pools
    Last Post: 06-19-2012, 04:47 PM
