Read www.poolsolutions.com and also search this forum for the BBB Method. This consists of Bleach (Cl), Borax (PH+), and Baking Soda (TA +). The math is real easy with bleach - 5.25% bleach will raise the Cl level 5.25ppm per 10,000 gallons of water. There are two tools out there, Ben's Buest Guess CYA chart which helps adjust the cl level per stabilizer level and Mike's BleachCalc program that provides the conversions and dosages. Also, if you get a good set of testing #s for your pool members can start providing guidance. Thanks
