Thread: Patio Pavers put a lot dirt in pool
    Orlando, Florida, USA.
    Default Patio Pavers put a lot dirt in pool
    I had cement patio pavers installed around my pool this week. I know I should have had the pavers done before the pool was opened but that's another story. Anyway now I have tons of cement dust in the pool and I can barely see the bottom.
    I ran the pump until the fliter clogged, cleaned it and ran the pump some more. I'll probably need to clean again tonight. I added Muratic Acid last night to lower the PH (was 8.0+). Pool is still cloudy and there is still some dirt on bottom.
    What do I need to do to lower the Ca in the pool? My readings this morning are:
    PH 7.5
    Alk 200
    CA 300
    CYA (didn't test - has been 40)
    CL 0 (added a gollon of bleach)
    TEMP 84
    Its a 18 to 20K inground gunite pool with Diamond Brite type finish. Thanks.
    mbar's Avatar
    Ashland, PA
    Default Re: Patio Pavers put a lot dirt in pool
    Your calcium is ok, but your alkalinity is too high - You can lower your ph down to 7.2 and aerate your water by turning your jets up so the water bubbles on the surface of the water. This will bring down your alkalinty while raising your ph. You will have to keep bringing down the ph with acid so you can continue to lower the alkalinity. You want your alk to be between 80 - 120. You can do a search on the forum for lowering alkallinity and it will explain everything for you.
    Your pool will clear with the filter running 24/7, and bringing your chlorine up to 15 ppms, as the chart shows with your cya about 40.
    Stabilizer . . . . . . Min. FC . . . . Max FC . . . 'Shock' FC
    => 0 ppm . . . . . . . 1 ppm . . . . . 3 ppm . . . . 10 ppm
    => 10 - 20 ppm . . . . 2 ppm . . . . . 5 ppm . . . . 12 ppm
    => 30 - 50 ppm . . . . 3 ppm . . . . . 6 ppm . . . . 15 ppm
    => 60 - 90 ppm . . . . 5 ppm . . . . . 10 ppm . . .. 20 ppm
    => 100 - 200 ppm . . . 8 ppm . . . . . 15 ppm . . .. 25 ppm
    Northeast PA
  1. Travertine Pool Patio
    By slater1182 in forum In-Ground Pool Construction and Repair
    Last Post: 01-21-2009, 12:10 AM
  2. Chipmunks digging under pavers
    By KirstenHW in forum Pools, Pets and Creepy Critters
    Last Post: 06-19-2008, 04:40 PM
  3. Pool pavers faded badly - Clean and seal advice Please
    By bell7272 in forum In-Ground Pool Construction and Repair
    Last Post: 07-31-2007, 06:38 AM
  4. Patio added near pool, pH thru the roof....
    By chrisexv6 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-19-2007, 10:05 AM
  5. Sealing Pavers
    By Simmons99 in forum In-Ground Pool Construction and Repair
    Last Post: 08-24-2006, 07:15 PM
