Thread: holes in hoses
    Default holes in hoses
    what is the best way to check for holes in kreepy krauler hoses. I am looking for the source of air into the pump/filter and only have air when the kreepy is installed. I rebuilt the ortega valve so I have no leaks there and so my next step is the hose sections. Will they spray when the hose is pulled out of the water or should I hear suction noises??
    Kannapolis, North Carolina
    Default Re: holes in hoses
    I usually hear sucking noises.
  1. Cleaning inside of hoses for winter
    By poolpuppy in forum Pool Equipment & Operations
    Last Post: 11-07-2012, 08:32 AM
  2. Better hoses for Intex pools?
    By IGnatius T Foobar in forum Intex-type Pool Setup & Operations
    Last Post: 07-23-2012, 02:04 PM
  3. Saltwater pump hoses crack frequently
    By mtnman2k1 in forum Intex-type Pool Setup & Operations
    Last Post: 07-14-2012, 07:38 PM
  4. Leaking hoses/hairline crack on skimmer
    By bssage in forum Pool Equipment & Operations
    Last Post: 07-13-2012, 11:04 AM
  5. Attaching Hoses Correctly
    By Steveromo in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 06-10-2012, 03:42 PM
