At this point, with a CYA of 80, you won't want to use any more dichlor or CYA. You can use cal-hypo for a little while if you still have it left but will want to monitor your CH reading. You don't want it to get too high. Your best bet is to just use plain, unscented bleach.
Take a look at this chart. It explains the connection between CYA and needed chlorine levels:> http://pool9.net/cl-cya/
For a CYA of 80, you'll see that you want to always keep your chlorine between 5-10ppm. Letting it drop below that is an invitation to algae. You'll probably want to bump the chlorine up a little this morning so you don't drop too low today.
The pH, TA are both just fine. You don't need any Borax or baking soda at this point.
(Until you registration is completed, you won't be able to see the rest of the forum while you are logged in. So, copy that link and then paste it into a browser window after you log out.)
Hope this helps!
