Thread: possible filter problem
    Default Re: possible filter problem
    Quote Originally Posted by drozdjeniferj View Post
    When putting filter on waste position, some of the algae was coming back into the pool through the jet! I did not think water was supposed to be coming back into pool on waste position. Is our brand new filter not working properly?
    Yep! It definitely should not do that.
    The very first thing to check is your multivalve on top (or side) of the filter.
    First logical answer is either the spider gasket has failed or is installed wrong. Replace.
    Second logical answer: One of the walls of the multivalve chambers is damaged and water is leaking through. You'll have to replace it.
    After that it gets too tough to guess.
  1. Problem Filter
    By Lenardo in forum Pool Equipment & Operations
    Last Post: 05-30-2010, 12:25 PM
  2. Filter Problem?
    By msb1766 in forum Pool Equipment & Operations
    Last Post: 08-24-2009, 08:33 PM
  3. Filter Problem???
    By lorettasweet in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 05-21-2007, 02:23 PM
  4. filter problem
    By rustin in forum Above-Ground Pool Construction & Repair
    Last Post: 05-14-2007, 12:10 AM
  5. Filter problem?
    By Pamsel in forum In-Ground Pool Construction and Repair
    Last Post: 06-20-2006, 10:30 AM
