Let's go ahead and have you shock the pool back up to see if we can clear up the water. With a CYA of 90ppm, your shock level is going to be 20ppm. You can see our chart that shows the relationship between CYA and chlorine here:> http://pool9.net/cl-cya/
In a pool this size, each quart of plain, unscented 8.25% bleach (generic Walmart is fine) will add about 2ppm of chlorine and each of the 121-oz jugs will add about 7.3. You can use those numbers as a reference to help you figure out how much to add.
With a CYA of 90, you're going to need the K2006 kit I mentioned previously so that you'll be able to measure the high chlorine levels that you are going to have to run to keep algae away. In the meantime you can use that color chart I linked up in my previous post that can help you deciper what the high chlorine levels look like on your OTO kit.
You'll want to keep your chlorine high until you can go from sundown one evening to within an hour or so of sunrise the next morning without losing more than 1ppm of chlorine AND you have a CC reading that is no higher than 0.5ppm AND your water is clear. (The K2006 can measure CC. Your kit cannot.)
I'm assuming that the Leslie's shock is dichlor which adds CYA. The trichlor tabs also add CYA. Honestly, your CYA is already too high. Don't use any more shock powder, just use plain bleach. Whether or not to use more of the trichlor tabs is a little more tricky. How many do you have left? Are they wrapped or unwrapped? If you log out and go to the top of the section of the forum called "Pool Chemicals and Pool Water Problems," there is a stickied thread that talks about what to do with leftover pool chemicals that you should read.
Keep an eye on your pH. You're ok at 7.2 but if it goes any lower, use some Borax to bump it up. By the way, it is the dichlor and trichlor that are causing it to be so low as they are both very acidic.
Run your pump 24/7 while you are trying to clear the pool, cleaning your filter as needed.
I'm assuming you have the cheap Intex cartridges. You'll have better luck if you replace those with some better ones. In our page that has our simple start-up recipe (which won't work for you, by the way), if you scroll down, it gives some info about replacing the cartridges with some other ones that are better. http://pool9.net/ssr/
(Remember, Until you registration is completed, you won't be able to see the rest of the forum while you are logged in. So, copy that link and then paste it into a browser window after you log out.)
Hope this helps. Come back if you have more questions and we'll try to help.
