Thread: LED light question
    sabres07 is offline Registered+ Thread Analyst sabres07 0
    May 2012
    Buffalo, NY
    Default LED light question
    I have a standard light niche and bulb in my in-ground pool. I was wondering if it will accept an LED bulb, the kind that changes colors, or does that require a whole different set up? I was at a friends house the other night and I really liked how his light was able to change colors slowly, or could be set to a single color.
    And are there any recommendations as to which brand I should be looking at?
    16'x32' oval 15K gal IG vinyl pool; liquid chlorine; Hayward cartridge filter; Hayward 3/4 hp pump; 3/5/2012hrs; Taylor 2006c; utility water; summer: none; winter: vinyl / water bags; ; PF:8
    Default Re: LED light question
    I replaced my standard 300 watt screw in bulb with a 546 led replacement light . I used the original socket and niche with no problems . It changes colors and modes by flipping the switch . Working good for 3 years now. I bought it from an ebay seller in New Zealand , was a little nervous about that transaction but the price was right and it arrived no problems. I did add a 12 volt transformer to convert from the original 110 volt , that may not have been required I think there were 110 volt options available but it gave me piece of mind . I have a 20 x 40 liner pool with a single light in the deep end and it is plenty of light .
  1. Light question
    By Themadczar in forum Pool Equipment & Operations
    Last Post: 07-03-2013, 10:19 PM
  2. Pool Light Question
    By gogolion in forum In-Ground Pool Construction and Repair
    Last Post: 07-03-2013, 12:10 PM
  3. Another Light Question
    By AmigaDude in forum Pool Equipment & Operations
    Last Post: 08-29-2011, 09:00 PM
  4. Assembly question on SAM light
    By mshumack in forum In-Ground Pool Construction and Repair
    Last Post: 07-05-2007, 08:51 AM
  5. Led Light Question
    By DONNIE in forum Pool Equipment & Operations
    Last Post: 07-28-2006, 07:20 AM
