Results 1 to 5 of 5
Thread: Is 6psi to low
    Jun 2014
    texas
    Default Is 6psi to low
    Hello all, I am new to the pool scene and just need a little help with my pressure. whats too high and too low. Im running a Starktools 2hp pump and a Hayward pro series sand filter model S220T with the vari-flow XL top mount valve. My pressure stays at around 6psi when clean I am just wondering if this is too low or not?
    Default Re: Is 6psi to low
    That seems low to me but I am certainly not the pump expert around here. We have been swamped in the past few days with new members so that is why your post has not yet gotten a reply but never fear, it will.
    Welcome to the Pool Forum!
    Jun 2014
    texas
    Ok thank you!! When Iturned everything on for the 1st time backwashed and rinsed pressure was at 13-14. After it rose and needed to be backwashed again is when it went down to 6psi. It is sitting at 10psi as of today.
    Jun 2014
    texas
    Well I finally figured it out!! lol WOW I had a brain fart I guess...I had valve turned the wrong way :/
    Glad you got it figured out.
