Thanks for the response. I have a Saltwater 8000 pool 18 x 33' by AquaLeader, Hayward sand filter and 1HP pump, Hayward Aqua Trol Saltwater system AQ-TROL-HP. So far, the 1st week we tested the water, Leslie's pool recommended 2 bags of Leslie's shock because chlorine was 0. Then, week 2, Salt was 3300 ppm. We added 26 lbs 4 oz Calcium Hardness because CH was 100. They also said to add 12 Qt of Instant Water conditioner (stabilizer) because the CYA was 0. FAC and TAC were both 2 ppm and they said that was ok. Week 3, Salt was 3400 ppm. FAC and TAC were 2 ppm. CH was 190, CYA was 40, TA 130, pH was 7.8. They recommended 1 lb. 12 oz of dry acid to bring TA down. They recommended adding more calcium hardness since it was 190 (range is 200-400), but I didn't think it mattered, so I didn't get it. Then, I added Free metal clear to see if that would get rid of the blue-greenish tint. That's all that has been added to date in my pool. After reading all the forums, I think I need to add Muriatic acid to lower the TA some more. Maybe that will clear up the water too, because it still isn't crystal clear.
I appreciate any advice to get my water chemistry accurate without breaking the bank. Also, how do I complete my registration so I can see the forum and do searches, etc. I don't mind sharing my address if thats what it takes. Thanks again, Cindy
