Thread: Dolphin and drain cover ..
    Smile Dolphin and drain cover ..
    I am having a problem with my dolphin getting caught on my main drains.
    I know they have a mat you can buy, but I need two at 70-80 each, plus
    I don't like the look of them.
    I have a newer pool, 2 years old, and I'd like to replace the anti vortex
    covers with something dolphin friendly. Has anyone ever done this?
    Default Re: Dolphin and drain cover ..
    Is it "physically" getting stuck due to the shape or is it getting stuck due to the main pump sucking it down? If the latter, why not run the Dolphin when the main pump is off then you won't have that problem.
    Davenj is offline Lifetime Member Thread Analyst Davenj 0
    Jersey Shore
    Mine is run with pump off, and it gets stuck once in a great while. It rides on top and doesn't allow the drives tracks or brushes top the bottom. I checked on the Hayward mat cover things, didn't like them for the price either.
    That sucks to hear as I just ordered a Dolphin Dynamic - hope I don't have that problem.
    Jersey Shore
    I got my Dolphin last year. Got hung up 2 or 3 times. I wouldn't worry about it. As well as it works and ease of use its no big deal.
    Palermo, NJ
    Thumbs up Re: Dolphin and drain cover ..
    My Dolphin was always getting stuck on the drains, to the point where I had to constantly check on it. Many times I would take the brush and push it off one drain, and it would go directly to the other drain and get stuck again!!! It didn't matter whether the pump was running on not, it would get stuck at least 5 or 6 times per cleaning. I finally broke down and bought 2 Polaris drain covers. It hasn't gotten stuck since. A costly solution, but now I can throw it in at night and wake up to a completely cleaned pool!
  1. getting cover to drain
    By ramsfan in forum --cleanup--
    Last Post: 12-11-2012, 06:11 PM
  2. main drain cover came off
    By robhair1 in forum In-Ground Pool Construction and Repair
    Last Post: 11-16-2007, 12:09 AM
  3. Is it necessary to drain winter cover/
    By poolbee in forum Pool Equipment & Operations
    Last Post: 10-17-2006, 11:44 AM
  4. replacing main drain cover
    By vinouspleasure in forum In-Ground Pool Construction and Repair
    Last Post: 07-31-2006, 09:06 PM
  5. Taking off the main drain cover?
    By jdolby in forum In-Ground Pool Construction and Repair
    Last Post: 06-03-2006, 03:38 PM
