Results 1 to 8 of 8
Thread: Methold of pouring bleach
    Apr 2014
    SE Louisiana
    Default Methold of pouring bleach
    I looked everywhere for this answer because I know it has to be here somewhere...but couldn't find it
    When you pour bleach directly into the pool....do you walk around the pool slowly pouring around the whole diameter of the pool.....or only pour the whole jug slowly in one spot and always in front of a return jet?
    Simple detail, but important question for me
    16x32 in-ground rectangle | chlorine pool | vinyl liner | k-2006 test kit
    May 2014
    Plano, TX
    Default Re: Methold of pouring bleach
    I pour directly into the skimmer. If you don't have a skimmer, pouring slowly into the return jet flow, or little all around the pool both will be fine. Our Intex liner DID bleach out some in one spot when my son poured 2 gallons of bleach all in one spot, as fast as it would pour. I'd recommend doing something to ensure that the bleach is dispersed somewhat rather than pouring in a concentrated area.
    Pappy
    Apr 2014
    SE Louisiana
    Oh great! I do have a skimmer but could have sworn at some point in the past I read not to pour bleach directly into the skimmer, only the baking soda, etc in there. Could totally be wrong though. Thanks for the reply!!
    Pappy is correct. It is perfectly fine to pour bleach directly into the skimmer. Pour it slowly and only when the pump is running.
    Apr 2014
    SE Louisiana
    Awesome!! Thanks! That will at least make it easier to pour and less likely splashing on my clothes like before having to hold the heavy bottle so far out from the liner...
    BigDave's Avatar
    Always wear old clothes when dosing bleach. The bleach seems to know when I haven't changed into my pool care clothes.
    Jul 2014
    Madison, WI
    I've been dumping off the diving board into the deep end of our pool. Is this OK? We have an outlet in the shallow end, with a 90 degree angle pipe directing the flow towards the deep end (down slightly to get the water at the bottom moving), a skimmer in the middle of the pool, and an inlet sucking straight in in the deep end. Is the chlorine just being sucked into the inlet and into our filter?
    26,000 gal IG vinyl liner pool (20'x40'), Waterway SMF-110 wet end w/ Century SQS-1072R motor, Pac-Fab Triton TR60 sand filter, K-2006A. Manually added chems: 12.5% NaClO liquid, granular CYA, baking soda, 31% muriatic acid.
    If you have an in-line chlorinator do NOT pour bleach into the skimmer!
    My preferred way is to pour the bleach directly into the return stream.
  1. Storing bleach outside; decomposition of bleach
    By tmess13 in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 10-03-2013, 08:24 PM
  2. water pouring out of equipment when pool was closed for winter
    By wishIcould in forum Pool Equipment & Operations
    Last Post: 01-09-2013, 05:08 PM
  3. Possible leak in new pool still under construction after pouring decking
    By krdowns in forum In-Ground Pool Construction and Repair
    Last Post: 08-15-2012, 09:55 PM
  4. Please Help! Rained while pouring concrete
    By rachunter in forum Pool Chemicals & Pool Water Problems
    Last Post: 07-17-2010, 05:32 PM
  5. Check Your Bleach Before Pouring Into Pool!!!
    By littleHeidi in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 04-13-2006, 01:30 AM
