You can disconnect the power leads to the copper ionizer. Be sure the SWCG is UNPLUGGED before you do it. After the leads to the copper bars are removed, you can run the SWCG without adding copper to the pool.
Pappy
Pappy
You do NOT need the copper electrode. You do NOT want copper in your pool. (Unless you like green hair!![]()
I've removed the copper electrode from the wire, but how do I replace the wire and housing?
