Thread: pump plug- tines form circle-
    Default pump plug- tines form circle-
    help- this is my first post.
    I just got a second hand pump as a gift and it has a different plug type
    having search the internet I believe it's a locking type plug, but couldn't find any picture.
    any chance I can get an adapter, or am I going to have a to have the pump plug rewired.
    I'm amazed at how much I have already learned here reading all the posts. I was reading to get rid of our above ground pool because of hassle but am looking forward to it now
    Morris, IL
    Default Re: pump plug- tines form circle-
    It is a twist lock plug, and you can get an adapter. I have one, but I ended up just rewiring the pump with a regular male plug. You should be able to get the adapter at your local pool shop I would say.
    haze_1956 is offline ** No working email address ** Thread Analyst haze_1956 0
    nj, usa.
    Or you can get a twist lock receptacle. Which may be required by code.
    thank you for the info
    the adpater is more our budget right now.
    we're only able to open the pool due to the hand me down pump/ filter due to budget constraints.
  1. New to the Form need help
    By Stockdalefamily in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-14-2011, 03:19 PM
  2. stripped plug nut, hayward super pump
    By docsobeck in forum Pool Equipment & Operations
    Last Post: 05-25-2011, 09:12 PM
  3. where to get concrete coping form
    By bcrumb in forum In-Ground Pool Construction and Repair
    Last Post: 05-22-2011, 02:05 PM
  4. Help! with blowing out the lines using the pump drain plug!
    By Amir in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 11-06-2007, 04:16 PM
  5. Tool for the pump basket plug?
    By hoffmans in forum Above-Ground Pool Construction & Repair
    Last Post: 08-17-2007, 07:07 AM
