Results 1 to 10 of 23
Thread: Solar Fish??
    mas985's Avatar
    Pleasanton, CA
    Default
    The primary chemical in heatsavr (Solar Fish) is isopropyl alcohol which changes the evaporation properties of water. Because a pool loses most of the heat through evaporation, this can help reduce heat loss as well. They claim as much as 40%. It is not as effective as a cover but a whole lot easier to use. I plan on trying it out this season to see how well it works.
    Here is a web site that has the technical information:
    http://www.flexiblesolutions.com/pro...ety_data.shtml
    Cedar Hill, TX (Dallas)
    Default
    The way I read the product description the alcohol is a carrier and quickly evaporates. The "active" ingredient is not named (other than by brand), even on the MSDS.
    Default
    Quote Originally Posted by mas985
    My understanding is that is is a proprietary susbstance in an isopropyl alcohol carreir or solvent. It is supposed to leave a molecule thick coating on the surface of the water. This leads me to believe it is some type of polymer. The MSDS that the above link goes to lists the isopropyl (commenly called rubbing alcohol) as the only hazardous ingredient since it is both toxic and flammable. Alcohol will disperse in water and not form a film on the surface. If you had enough in the water it would evaporate first but you would need to have a pretty strong mixture...probably over 50% to have any appreciable effect!
    mas985's Avatar
    Pleasanton, CA
    Default
    oops, I guess I missed the note on the primary chemical. Sorry. However, the effectiveness test do show some promise.
    http://www.flexiblesolutions.com/pro...ss_tests.shtml
  1. Replacing Solar thermal and natural gas with Solar PV and electric pool heater
    By California Newbie in forum Pool Equipment & Operations
    Last Post: 05-26-2012, 07:14 PM
  2. Opening pool late - What to do with frog fish?
    By olavski in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 06-29-2009, 04:07 PM
  3. Opening pool late - What to do with frog fish?
    By olavski in forum In-Ground Pool Construction and Repair
    Last Post: 06-09-2009, 08:26 AM
  4. solar cover 'fish"
    By tmack in forum Pool Equipment & Operations
    Last Post: 06-14-2006, 09:06 AM
  5. A plus for solar fish
    By salinda in forum Pool Equipment & Operations
    Last Post: 05-16-2006, 12:59 PM
