Results 1 to 10 of 39
Thread: Start up chemistry for first time pool owner
    May 2014
    Lynbrook, NY
    Default Re: Start up chemistry for first time pool owner
    Watermom thank you for asking
    Unbelievable beautiful crystal clear
    I also used a HTH 6 way test kit to double check the chlorine level and was way above the scale.
    Eddie
    Summer Escapes 14' Pro-Series 4047 gallons, Intex 12 inch sand pump, Intex SWCG, Intex 2500 GPH Filter Pump, surrounded by Vinyl Works Fence using a Taylor K-2006C and Taylor K-1766, Sungrabber 4 x 12 feet Solar Collector, Hayward Aqua Solar GL-235, 12 mil Clear Solar Blanket
    If your water is clear and you have a CC reading of 0, then let your chlorine level drift down. (Now I see that you stated in your previous post that the water was clear. Sorry I missed that.)
    May 2014
    Lynbrook, NY
    Watermom you never need to apologize.
    I will just vacuum my pool tomorrow and vacuum my pool. I will check all my levels early evening.
    Can my children go in the pool with such high level of FC?
    Eddie
    Ben would most likely tell you go ahead and swim but just wear old suits. I'm a little more conservative and though it is probably fine, if it were my kids, I'd probably wait until it came down to under 20 (with a CYA of 60) and then wear an old suit that it won't matter if it fades.
    By the way, no need to check everything every day when you aren't having problems. Just check chlorine and pH but if your chlorine is above 10ppm (with a Taylor kit), you'll need to dilute your water sample (half pool water and half distilled water mixed together) and then run the pH test with that.
  1. Super-simple recipe for Intex type swimming pools
    By PoolDoc in forum Pool Chemistry for Intex-type Pools
    Last Post: 07-07-2018, 09:22 AM
  2. chemistry for filling pool for the first time
    By vinouspleasure in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-07-2011, 05:16 PM
  3. Brand New Pool Owner wants to start off on the right foot!
    By StuckiTribe in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-11-2010, 08:29 PM
  4. New Pool owner water chemistry
    By sammm in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 05-11-2007, 09:56 AM
  5. New Pool Owner/Chemistry Worry?
    By mkfmedic in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-22-2006, 02:42 PM
