Results 1 to 10 of 39
Thread: Start up chemistry for first time pool owner
    May 2014
    Lynbrook, NY
    Default Re: Start up chemistry for first time pool owner
    Your right should have scrolled back I apoligize
    BigDave's Avatar
    Sorry, I didn't mean to be grumpy.
    May 2014
    Lynbrook, NY
    FYI, just got my Taylor K-2006C, my Aquachek salt strips. Will keep everyone in the loop in the next couple of days.
    http://i1175.photobucket.com/albums/...g?t=1404230856
    Good deal. These testing demo videos may be helpful to you:> http://pool9.net/K2006-vid/
    May 2014
    Lynbrook, NY
    BigDave
    Is it possible if you can PM me?
    BigDave's Avatar
    I don't think PM works here. What's up?
    May 2014
    Lynbrook, NY
    BigDave
    You have been so much help, along everyone else. I like to summarize first time pool setup for my pool.
    PLEASE DONT CALL ME STUPID, i just want to make sure i do this correct the first time. I dont want to come to the forum in tears. LOL
    I got a bit confused between the bleach and dichlor method for my pool running a salt water generator.
    1. Begin the fill of my pool, add some bleach
    2. Continue to add bleach until the pool is fill
    3. After the pool is full add the dichlor
    4. Test the water
    5. If everything is perfect, begin to add salt
    6. Begin my filter pump
    7. Test the water
    8. Begin the SWCG
    Would you say perform the steps in this manner, please add any comments you like.
    BigDave's Avatar
    I hope I haven't given you cause to think I'd call you stupid; the only times I recall using that word here is when I've written "The only stupid questions are unasked".
    Your steps look good to me. I'll embellish a little.
    1. Begin the fill of my pool, add doses of bleach as per the 7-Day Start-up of the SSR.
    2. Continue to add doses of bleach until the pool is fill as per the 7-Day Start-up of the SSR.
    2.5. Begin my filter pump when water is deep enough to cover inlet and outlet of pool.
    3. After the pool is full add doses of dichlor and borax as per the Pool Care Plan of the SSR until three pounds of dichlor have been used.
    4. Test the water for FC, CC, pH daily; once for CYA and TA after using 3lbs diclhor.
    5. If CYA is between 30 and 60, pH is between 7.2 and 7.8, TA is between 50 and 150, FC is between 4 and 8, and CC is 0.5 or less, begin to add salt
    7. Test the water (see 4)
    8. Begin the SWCG
  1. Super-simple recipe for Intex type swimming pools
    By PoolDoc in forum Pool Chemistry for Intex-type Pools
    Last Post: 07-07-2018, 08:22 AM
  2. chemistry for filling pool for the first time
    By vinouspleasure in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-07-2011, 04:16 PM
  3. Brand New Pool Owner wants to start off on the right foot!
    By StuckiTribe in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-11-2010, 07:29 PM
  4. New Pool owner water chemistry
    By sammm in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 05-11-2007, 08:56 AM
  5. New Pool Owner/Chemistry Worry?
    By mkfmedic in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-22-2006, 01:42 PM
