Thread: New motor or new pump?
    TomC is offline PF Supporter Thread Analyst TomC 0
    New York
    Default New motor or new pump?
    After a day or two of making high pitched squealing sounds, my Whisperflo Dual speed pump motor finally died. When I try to power it up it just hums. The model of the pump is WFDS-26. It's about 13 years old. I can buy a new motor, shaft seals and gaskets for about $400. I can buy the same exact pump for about $620. So here are my questions:
    1. For a $200 difference do you think I should buy the whole new pump, it seems like a better deal to me.
    2. Is there a better pump out there for my money?
    3. The only water feature I have is a pool slide, and the current pump, 1.5/ 0.25 hp, had no problem sending enough water to it.
    4. I'm not inclined to upgrade to intelliflo for a third more in price
    I did call my pool guy when the pump first started acting up 2 days ago, but he hasn't gotten back to me yet.
    Any and all advice appreciated.
    Tom
    20'x42' L' 41K gal IG vinyl pool; trichlor feeder, bleach; Pentair 420 cartridge filter; Pentair Whisperflo 1.5hp 2 speed pump; hrs; TF-100, CYA test; city;PF:2.9
    Mar 2014
    NC
    Default Re: New motor or new pump?
    When we bought this house 14 years ago, our pump was very noisy. I managed to get a rebuild kit for the motor itself for just a few buck and did the work myself. Just pay attention to how the motor comes apart and you could save a bunch of money. FYI--- Still working fine after all this time and many years of running 24/7.
    25,750 ga 18x36 Rectangle IG Vinyl liner; Hayward 250 sand filter; 1.5 hp pump. PF=4.4
    May 2014
    Florida
    Hi Tom - If it were me I would go with the B2982T dual speed replacement motor which comes with a digital timer, this motor can be found for $335 you would also need a 5250-106 seal which is about $15 this is a 1 HP full rate motor which would be identical to your 1.5 HP up rate motor. The B2982T has a digital timer right on top of the motor for easy programming. There typically is really no need to replace the pump housing and replacing the motor would be fine.
    Inyopools
    Mar 2014
    NC
    @TomB --- you really don't need to run your pump 24/7. It will save you quite a bit of $$$ on power bills if you don't. 8-10 hours per day would be more than plenty.
    Yes... I know that NOOOWWWWW ;-) ... But I didn't know it when I was spending many thousands at the pool store every season. You keep forgetting what an idiot I was prior to finding this forum :-D I think I have the timer set to run it 10-11 hours a day (in two cycles) now.
    New York
    Thanks for all the replies. I was able to find the entire pool pump online for $559, no tax, free shipping. I got it in about 2 days. Even though I had no filtration for about 5 days my pool stayed clear. I just ran my aquabot about 6 hours a day and my pool stayed nice and clean. I had to hand skim it though, no biggie, that's why I have sons
    So the direct replacement for my whisperflo WFDS-26 pump was.....the same exact model. So I disconnected the old pump, rewired and connected the plumbing to the new pump and I was in business.
    Yesterday, I took apart my old motor apart to find that the bearings were seized, maybe just one, but maybe both. I couldn't remove them. We have a guy here in town that fixes and rebuilds motors, he did my brother's pool motor 2 or 3 years ago. I'm going to bring it to him today, he said on the phone it may take him a week until he gets to it, and that the 2 bearings, motor shaft seal, should be less than a hundred bucks. I figure I'll keep it as a spare, or as an auxiliary pump should I ever get around to adding that waterfall my wife wants.
    Tom
  1. Replies: 2
    Last Post: 08-04-2013, 09:37 AM
  2. Recommendations For Replacement Pump Or Pump Motor (1.5" Piping, High Head)
    By ChuckDavis in forum Pool Equipment & Operations
    Last Post: 05-25-2013, 03:56 PM
  3. Replace motor or pump and motor?
    By myLABSpool in forum Pool Equipment & Operations
    Last Post: 05-25-2013, 01:13 PM
  4. One motor primes pump another motor wont????
    By jmurch in forum --cleanup--
    Last Post: 12-17-2012, 10:47 AM
  5. Replace motor or motor& pump?
    By jtcaputo in forum Pool Equipment & Operations
    Last Post: 09-08-2012, 07:27 PM
