Hey all. first I would like to say this forum bailed me out when I bought a house that had a green pool. I learned a lot by being a lurker, but I was well informed. Thank you.
Here's my current problem. About 3 months ago I had to turn the green pool around. Then I had to battle a very high CYA level, drained way more than I should of and got very low CYA levels, almost nothing. Brought the level back up to about 30 ppm slowly using conditioner. This was all over the coarse of about a week. Pool was clear and clean, only have to balance it about once a week and add chlorine a couple times a week-I live in the heat. So for the past couple months all has been good. About 3 days ago I tested my CYA level for about the 3rd time since adjusting it. It tested high, like 70 ppm. Remember, it was always around 30 ppm for weeks and weeks. I tested it again yesterday, and I'm about 70-80 ppm. I use the Taylor K-2006 kit. I also DO NOT use tabs or anything that has Dichlor or Trichlor in it. I'm strictly liquid, and no powdered shock.
So there's my problem, I don't know how it's going up, but it is. Only chemicals I put in the pool are, unbalanced liquid chlorine, muratic acid and baking soda. I'll use a clarifier every once in a while.
Thanks in advance for any help.
Robert
