You have 1 ppm copper in your pool! (or is it iron?) Either one can cause the water to color with high levels of chlorine. Is the water clear or cloudy? If it is clear and colored and your metal level is that high then use a sequesterant to see if that uncolors your water. Copper will cause a greenish tint to the water and iron will be yellow to brownish. (If you liner is blue then yellow water from iron will look greenish. Do you know how the metals got in your water in the first place? Do you use well water? (Iron is a big problem with some well water). Did you overdose on copper based algaecide (about .3 to .6 ppm copper is enough to be an effective algaecide). Shocking your pool when the metal level is that high is not a good idea. If the water is cloudy and colored then it's most likely algae.
